tomt42nj
#1 Posted : 12 years ago
tomt42nj
Water is not going into the ice maker. I have determined that the inlet water valve is working. Should I replace the whole ice maker or just the ice maker control module?
bmp999
#2 Posted : 12 years ago
bmp999
I have fixed this a number of times on our ice maker (Maytag). Every time it was that the water inlet was frozen. I defrosted the freezer and used a hair dryer to add the needed heat (but not too much) to the inlet pipe in the freezer going to the ice maker. A big 1/2" diameter cylinder of ice would eventually fall out. I added a piece of pool noodle with a hole through it to help insulate the tube to the ice maker (about 4" long in my case). Helpped a bit, but would do it again over time. Generally once a year I had to do this.
Hope this helps.
Brian
#3 Posted : 12 years ago
Go in the back and temporarily swap the water solenoid connectors, then press the water dispenser lever for 6 to 9 seconds, icemaker mold should fill up, if not, you have a frozen water line. If so, check the freezer temperature, probably too low, should be between zero and 5 degrees.
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 2 years ago
sears whirlpool icemaker wont stop making ice (Refrigerator & Freezer Repair)
by retiredfornow 7 years ago
New Whirlpool Icemaker - works when I jiggle it before each cycle (Refrigerator & Freezer Repair)
by ATXGuy 9 years ago
Whirlpool Icemaker Wire Arm Stays Up , Ice Bin Empty (Refrigerator & Freezer Repair)
by adkinstracy39 10 years ago
replaced whirlpool icemaker...getting nothing (Refrigerator & Freezer Repair)
by bruce079 11 years ago
kitchenaid whirlpool icemaker trouble (Refrigerator & Freezer Repair)
by msteve 12 years ago
Whirlpool Icemaker Not Filling With Water (Refrigerator & Freezer Repair)
by jgibby65 12 years ago
New Whirlpool Icemaker making icicles (Refrigerator & Freezer Repair)
by LouTx 12 years ago
whirlpool icemaker wont make ice (Refrigerator & Freezer Repair)
by boscher99 13 years ago
whirlpool icemaker (Refrigerator & Freezer Repair)
by rdstrhef 13 years ago
Whirlpool Icemaker (Refrigerator & Freezer Repair)
by TracyShel 13 years ago
Whirlpool Icemaker Not Working (Refrigerator & Freezer Repair)
by dtnel 13 years ago
Whirlpool Icemaker Issue (Refrigerator & Freezer Repair)
by Indy2727 13 years ago
New Whirlpool icemaker not dumping (Dishwasher Repair)
by nowchinatown 14 years ago
by HarleyMike 14 years ago
