tomt42nj
#1 Posted : Sunday, March 17, 2013 6:53:45 AM(UTC)
tomt42nj
Water is not going into the ice maker. I have determined that the inlet water valve is working. Should I replace the whole ice maker or just the ice maker control module?
bmp999
#2 Posted : Sunday, March 17, 2013 7:16:12 AM(UTC)
bmp999
I have fixed this a number of times on our ice maker (Maytag). Every time it was that the water inlet was frozen. I defrosted the freezer and used a hair dryer to add the needed heat (but not too much) to the inlet pipe in the freezer going to the ice maker. A big 1/2" diameter cylinder of ice would eventually fall out. I added a piece of pool noodle with a hole through it to help insulate the tube to the ice maker (about 4" long in my case). Helpped a bit, but would do it again over time. Generally once a year I had to do this.
Hope this helps.
Brian
#3 Posted : Sunday, March 17, 2013 10:33:55 AM(UTC)
Go in the back and temporarily swap the water solenoid connectors, then press the water dispenser lever for 6 to 9 seconds, icemaker mold should fill up, if not, you have a frozen water line. If so, check the freezer temperature, probably too low, should be between zero and 5 degrees.
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sears whirlpool icemaker wont stop making ice (Refrigerator & Freezer Repair)
by retiredfornow 3/27/2018 12:51:15 PM(UTC)
New Whirlpool Icemaker - works when I jiggle it before each cycle (Refrigerator & Freezer Repair)
by ATXGuy 12/17/2015 9:20:24 AM(UTC)
Whirlpool Icemaker Wire Arm Stays Up , Ice Bin Empty (Refrigerator & Freezer Repair)
by adkinstracy39 7/7/2015 7:46:19 AM(UTC)
replaced whirlpool icemaker...getting nothing (Refrigerator & Freezer Repair)
by bruce079 12/20/2013 8:00:20 AM(UTC)
kitchenaid whirlpool icemaker trouble (Refrigerator & Freezer Repair)
by msteve 6/14/2013 11:53:46 AM(UTC)
Whirlpool Icemaker Not Filling With Water (Refrigerator & Freezer Repair)
by jgibby65 1/28/2013 2:13:27 PM(UTC)
New Whirlpool Icemaker making icicles (Refrigerator & Freezer Repair)
by LouTx 10/27/2012 7:38:20 AM(UTC)
whirlpool icemaker wont make ice (Refrigerator & Freezer Repair)
by boscher99 8/27/2012 5:31:22 PM(UTC)
whirlpool icemaker (Refrigerator & Freezer Repair)
by rdstrhef 8/14/2012 6:51:34 AM(UTC)
Whirlpool Icemaker (Refrigerator & Freezer Repair)
by TracyShel 5/23/2012 8:04:39 AM(UTC)
Whirlpool Icemaker Not Working (Refrigerator & Freezer Repair)
by dtnel 5/4/2012 8:04:24 AM(UTC)
Whirlpool Icemaker Issue (Refrigerator & Freezer Repair)
by Indy2727 1/17/2012 8:37:54 AM(UTC)
New Whirlpool icemaker not dumping (Dishwasher Repair)
by nowchinatown 10/3/2011 3:18:17 PM(UTC)
by HarleyMike 7/20/2011 7:11:50 PM(UTC)
