Goldie01
#1 Posted : Tuesday, January 15, 2013 2:49:21 PM(UTC)
Goldie01
We have a used dishwasher, and it has started doing this: when the arm spins around, it rakes across the heating element, & makes a knocking sound, is there a way I can fix it or will I have to buy another spray arm? and how do I attach it to it's base?
#2 Posted : Wednesday, January 16, 2013 1:57:46 PM(UTC)
Hello,
Make sure the lower spray arm support (#62 at the diagram) and the spray arm installed properly.
Check both, the spray arm and the support.
- The lower spray arm Part number: 154568001
- The lower spray arm support Part number: 154294101
Goldie01
#3 Posted : Wednesday, January 16, 2013 9:49:53 PM(UTC)
Goldie01
I removed the spray arm & examined it & couldn't see anything wrong with it, so I put it back on & ran a empty cycle & the tip ends would tap against the heating element...have you ever heard of this happening before? If there is something I can adjust, I can probably fix it myself....please give me your opinion. Thanks for the feedback.
#4 Posted : Thursday, January 17, 2013 1:48:40 PM(UTC)
There are no any adjustments. Try to replace the spray arm.
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 9:28:24 AM(UTC)
Assemble filter and lower spray arm on dishwasher (Dishwasher Repair)
by Pat Armstrong 7/21/2014 6:23:47 AM(UTC)
Amana: Lower Spray Arm Falls Off (Dishwasher Repair)
by 400wash 2/24/2014 5:48:41 AM(UTC)
Replacing lower spray arm KitchenAid dishwasher (Dishwasher Repair)
by IggyDad 9/11/2013 2:56:37 PM(UTC)
Can't remove lower spray arm (Dishwasher Repair)
by stumpedinCA 1/18/2013 4:07:42 PM(UTC)
How to remove lower spray arm on GE dishwasher GSD4060n10ss (Dishwasher Repair)
by fo1rd 1/14/2012 12:19:41 PM(UTC)
Take apart Whirlpool lower spray arm assembly (Dishwasher Repair)
by valv00 1/12/2012 4:36:53 PM(UTC)
Maytag Dishwasher - lower spray arm not spinning (Dishwasher Repair)
by MarkOpti 8/1/2011 6:55:17 PM(UTC)
Remove Lower Spray Arm on GE Profile DW (Dishwasher Repair)
by A1driller 3/6/2011 12:54:33 PM(UTC)
Lower spray arm (Dishwasher Repair)
by hilreal 12/8/2010 4:22:02 PM(UTC)
lower spray arm won't rotate (Dishwasher Repair)
by pap2labc 7/1/2010 11:23:37 AM(UTC)
Lower Spray Arm removel (Dishwasher Repair)
by marcusa123 2/16/2010 6:27:25 PM(UTC)
How do I remove the lower spray arm on a GE dishwasher? (Dishwasher Repair)
by Chefdouglas 10/28/2009 3:21:50 AM(UTC)
