Sorry for the mistake. I did replaced the control board on the top of the refrigerator not the control pannel.
Groups: APP Team
What is the part # of the board? Did you replace the condenser motor?
Simon.
Originally Posted by: Simon / APP Team  What is the part # of the board? Did you replace the condenser motor?
Simon. Hi Simon: The part number for the board is W10219463 which is the part number on the WEB site. I did not replace the Fan condenser motor. The fan seemed to be working at the time I tested the system, in fact the fan started up when the system cools down. It stays on for about 30 to 60 min and then turns off. Should I also replace the fan motor?
Groups: APP Team
What is the complete model number?You are missing 2 numbers.
You should replace both control and fan as I stated in the previous post.
Simon.
Originally Posted by: Simon / APP Team  What is the complete model number?You are missing 2 numbers.
Simon. Model number for the refrigerator is: KSSC48QMS02 I will replace the fan as you recommend.
Groups: APP Team
Hi.
Please do so and post the results.
Simon.
Simon. Hi Simon: I have a question on the fan. I tested the fan when I turn the system on and the voltage is correct and the fan is working fine for about one hour. It's when the system start to heat up that the fan turns off. There is no electricity going to the fan after that. It seems to be doing the exact opposite of that it should be doing. Is there a heat control part to the coils that might be malfunctiing? Please let me know. I just hate to buy a part if it's not what I need. Thanks for all your help. Al
Simon. Simon: another question. Could this be a bad Inverter control box??
Groups: APP Team
Hi.
Both fans (evaporator and condenser) and compressor turns off when the fridge is going into self defrost for about 30 min. If you replaced the control board and condenser fan stops you should replace it.It's a general recommendation to replace them together because the damaged motor may "kill" a brand new board.
There is no any condenser temperature control devise for your model. The inverter is only controlling the compressor.
Simon.
Simon. Received the fan and installed it. Everything started up just as it should. The condenser fan was running and then stopped. The coils started to heat up and the fan never turned back on. The fan only runs if the system is cold. I can leave the system off for several hours and when I start it up everything works. I have no idea what else I can do.
