Groups: APP Team
Hi.
Check wiring and connections from the fan motor to the control board. Get another control board, return the old one.
Simon.
Simon. I called the company that sold me the control board and they have transfered this to the warranty dept. I might have received a bad board. Hope so. I will let you know. Thanks AL
Groups: APP Team
Hi Simon:
The company that sold me the control bd did in fact send me a new board. I installed the board and the problem is fixed. It does seem like I received a bad board from the company initially, but they did send a replacement immediately and I was able to fix the problem. I took long enough and I would like to thank you for all your help.
Al
Groups: APP Team
Originally Posted by: Simon / APP Team  You are welcome.
Simon. Hi Simon: It seems like the problems never go away. The refrigerator is having new problems. This time the over temp reset lights up. the temp in the freezer is -10 and 54 in the frig. I hope its not the main control board again. Hope to hear from you soon. Al
Originally Posted by: alhero  At first there was a noice coming from the top of the refrigerator. I think it was the condeser Fan. Now the fan does not start and the lights in the control panel blink on and off. The refrigerator seems not to cool up to the set degrees. Also, The condeser coils on top of the refrigerator are very hot.
Do I need to replace the condenser fan??
Need help. I live in a rural area and the repair company doesn't seem to know what the problem is. Not sure if they have ever worked on a sub zero system. Simon: I need some additional help
Groups: APP Team
Hello.
What seams to be a problem?
Simon.
Simon. It seems like the problems never go away. The refrigerator is having new problems. About 6 month ago I changed the control board and everything seems to be working fine. This time the "over temp reset" lights up. the temp in the freezer is -10 and 54 in the refrigerator. I hope its not the main control board again. I have to reset the Over Temp Button several times a day to have the system maintain a normal temp setting. Hope to hear from you soon. Al Read more: http://forum.appliancepartspros...rator.html#ixzz2U46oIFVS http://forum.appliancepartspros.com
Hi Simon
Hope you can help me with the refrigerator. My Kitchen Aid KSSC48QMS02 is having a problem with the auto defrost. The temp of the freezer goes up to -10 and the refrigerator goes up to 45. Denman was helping but I have not heard from him a some time.
The only way for the refrig to go back to normal is for the system to be turned off for a day and then it works for another 2 - 3 months.
