3 Pages<123>
alhero
#11 Posted : Friday, October 26, 2012 1:08:35 PM(UTC)
alhero
Sorry for the mistake. I did replaced the control board on the top of the refrigerator not the control pannel.
Simon / APP Team
#12 Posted : Friday, October 26, 2012 2:00:37 PM(UTC)
Simon / APP Team
Groups: APP Team
What is the part # of the board? Did you replace the condenser motor?
Simon.
alhero
#13 Posted : Friday, October 26, 2012 2:12:06 PM(UTC)
alhero
Simon.
Hi Simon: The part number for the board is W10219463 which is the part number on the WEB site. I did not replace the Fan condenser motor. The fan seemed to be working at the time I tested the system, in fact the fan started up when the system cools down. It stays on for about 30 to 60 min and then turns off. Should I also replace the fan motor?
Simon / APP Team
#14 Posted : Friday, October 26, 2012 3:01:45 PM(UTC)
Simon / APP Team
Groups: APP Team
What is the complete model number?You are missing 2 numbers.
You should replace both control and fan as I stated in the previous post.
Simon.
alhero
#15 Posted : Friday, October 26, 2012 3:20:23 PM(UTC)
alhero
Simon.
Model number for the refrigerator is: KSSC48QMS02
I will replace the fan as you recommend.
Simon / APP Team
#16 Posted : Friday, October 26, 2012 3:37:51 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please do so and post the results.
Simon.
alhero
#17 Posted : Saturday, October 27, 2012 9:06:41 AM(UTC)
alhero
Hi.
Simon.
Hi Simon:
I have a question on the fan. I tested the fan when I turn the system on and the voltage is correct and the fan is working fine for about one hour. It's when the system start to heat up that the fan turns off. There is no electricity going to the fan after that. It seems to be doing the exact opposite of that it should be doing. Is there a heat control part to the coils that might be malfunctiing?
Please let me know. I just hate to buy a part if it's not what I need.
Thanks for all your help.
Al
alhero
#18 Posted : Saturday, October 27, 2012 9:19:18 AM(UTC)
alhero
Hi.
Simon.
Simon: another question. Could this be a bad Inverter control box??
Simon / APP Team
#19 Posted : Saturday, October 27, 2012 2:48:37 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Both fans (evaporator and condenser) and compressor turns off when the fridge
is going into self defrost for about 30 min.
If you replaced the control board and condenser fan stops you should replace it.It's a general recommendation to replace them together because the damaged motor may "kill" a brand new board.
There is no any condenser temperature control devise for your model.
The inverter is only controlling the compressor.
Simon.
alhero
#20 Posted : Friday, November 2, 2012 9:14:25 AM(UTC)
alhero
Hi.
Simon.
Received the fan and installed it. Everything started up just as it should. The condenser fan was running and then stopped. The coils started to heat up and the fan never turned back on. The fan only runs if the system is cold. I can leave the system off for several hours and when I start it up everything works.
I have no idea what else I can do.
Guest (5)
Kscs25fvms01 kitchen aid refrigerator (Refrigerator & Freezer Repair)
by Guest 9/10/2021 1:42:56 PM(UTC)
Kitchen Aid refrigerator click buzz click - not cooling (Refrigerator & Freezer Repair)
by adfonseca 3/11/2021 3:18:11 PM(UTC)
Kitchen Aid Refrigerator Issue (Refrigerator & Freezer Repair)
by vta1605 2/25/2021 9:45:52 AM(UTC)
Kitchen Aid Refrigerator KSC24C8EYY02 (Refrigerator & Freezer Repair)
by Carlos trio 5/18/2020 12:53:17 PM(UTC)
Loud intermittent sound from Kitchen Aid Refrigerator (Refrigerator & Freezer Repair)
by Adam_W 4/18/2018 9:01:28 AM(UTC)
Kitchen Aid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by txh123 10/26/2016 5:27:11 PM(UTC)
Kitchen aid refrigerator water filter/housing leak (Refrigerator & Freezer Repair)
by timspillane 3/18/2014 7:27:33 AM(UTC)
Kitchen Aid Refrigerator LED Display not working (Refrigerator & Freezer Repair)
by TroyJ 1/17/2014 3:02:20 PM(UTC)
by alhero 5/8/2013 11:52:27 AM(UTC)
Kitchen aid refrigerator with a non working ice maker (Refrigerator & Freezer Repair)
by ts6268 1/18/2013 10:08:47 AM(UTC)
Replacing door gasket seal on side by side Kitchen Aid Refrigerator (Refrigerator & Freezer Repair)
by curtisn 11/20/2012 3:00:41 PM(UTC)
Kitchen Aid Refrigerator Ice Maker Not Working (Refrigerator & Freezer Repair)
by Dan0354 12/6/2011 6:51:54 PM(UTC)
Fix 1987 Kitchen Aid Refrigerator or buy new? (Refrigerator & Freezer Repair)
by hanswagner 9/6/2011 1:12:04 PM(UTC)
Problem with kitchen aid refrigerator kbfa25erss01. (Refrigerator & Freezer Repair)
by AMINAZIZ 6/21/2011 9:55:44 AM(UTC)
Kitchen Aid Refrigerator Freezer not cool enough (Refrigerator & Freezer Repair)
by mjmock 6/15/2011 1:56:20 AM(UTC)
3 Pages<123>
