easymoney12
#1 Posted : Tuesday, September 18, 2012 3:49:06 PM(UTC)
easymoney12
Lookin for help. Lightining ran in on my stove & got my control panel. Replaced it but my Oven will not light. Replaced the igniter & still won't light. I have 120volts going to igniter & coming out other wire but the igniter coil does not glow. The broiler does light though. What's up with that?
Simon / APP Team
#2 Posted : Tuesday, September 18, 2012 6:42:57 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to touch both igniter contacts with your meter probes to see if there is 120VAC going to the igniter. If not - check the gas valve coil for continuity.
Post the results.
Simon.
easymoney12
#3 Posted : Wednesday, September 19, 2012 2:52:11 PM(UTC)
easymoney12
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Hello Simon, I do have 120vac at my igniter, but it does not glow. I also have 120vac coming out of the igniter. Does this mean my new igniter was bad, or am I missing something? Thanks
Simon / APP Team
#4 Posted : Wednesday, September 19, 2012 4:08:52 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Could you please explain what do you use and how you check the voltage at the igniter.
Simon.
easymoney12
#5 Posted : Thursday, October 11, 2012 2:42:35 PM(UTC)
easymoney12
Hi Simon, I turn the stove on and use a meter to check for the voltage at the igniter wires.
Simon / APP Team
#6 Posted : Thursday, October 11, 2012 3:25:58 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
To check the voltage you need to disconnect the ignitor and touch each supply wire with you meter probe, reading the voltage between two supply wires.
Simon.
easymoney12
#7 Posted : Friday, October 12, 2012 2:42:46 PM(UTC)
easymoney12
Hi Simon, with the igniter disconnected, across the wires the meter reads .3. What should I have?
Simon / APP Team
#8 Posted : Friday, October 12, 2012 3:39:58 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the continuity of the safety gas valve coil (the bake part of it). If no continuity - replace it.
Safety valve Part number: WB19K14
Post the results.
Simon.
easymoney12
#9 Posted : Friday, October 12, 2012 5:46:34 PM(UTC)
easymoney12
Hi Simon, if I am correct, the top terminals are the broiler & across them I have continuity. I don't have continuity across the bottom terminals. Is the gas valve fixable or is it replacement only? Thanks
Simon / APP Team
#10 Posted : Sunday, October 14, 2012 1:53:29 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to get a new valve.
Simon.
Kitchenaide gas oven will not light (Oven Repair (including Ranges and Cooktops))
by insurancelady66 2/20/2013 10:50:22 AM(UTC)
magic chef oven will not light (Oven Repair (including Ranges and Cooktops))
by david_r_shultz 1/14/2013 1:11:44 PM(UTC)
by gypsyqueen 5/24/2012 8:50:45 AM(UTC)
by applianceproparts 5/2/2012 7:16:40 AM(UTC)
Gas Oven will not light (Oven Repair (including Ranges and Cooktops))
by GregM41 4/19/2012 7:28:11 AM(UTC)
by ACummings 3/27/2012 1:51:01 PM(UTC)
Oven will not light, no light on control panel but timer works (Gene) (Oven Repair (including Ranges and Cooktops))
by Xray39 10/29/2011 11:06:27 AM(UTC)
by mikenpd133 10/6/2011 6:30:33 AM(UTC)
burner on oven will not light (Oven Repair (including Ranges and Cooktops))
by jmwr 7/26/2011 5:31:55 PM(UTC)
by C Dale 7/16/2011 5:11:14 AM(UTC)
by flustered 7/4/2011 4:37:01 PM(UTC)
burners work but oven will not light (Oven Repair (including Ranges and Cooktops))
by jwohlf 4/28/2011 9:44:35 AM(UTC)
by jdiddle 10/1/2010 4:38:38 AM(UTC)
by texjett 9/2/2010 5:17:08 PM(UTC)
by PatY 8/16/2010 6:34:08 PM(UTC)
