ian33
#1 Posted : 12 years ago
ian33
Hey everyone I am in desperate need of some incite. My Broiler is not functioning at all on my range. No fault codes appear. I bought a new broiler element and that has not fixed the issue. Any help would be greatly appreciated!! The model is RF263LXTT1
cheers
Ian
#2 Posted : 12 years ago
Replacement parts for Whirlpool RF263LXTT1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE | AppliancePartsPros.com
The thermal fuse (Item 17 in Section 1) may have blown. It kills power to the broil element.
Un[plug the unit and one wire from the fuse and check it with a meter. Should be 0 ohms.
ian33
#3 Posted : 12 years ago
ian33
Thanks i shall check that tonight! Are there any other possibilites?
#4 Posted : 12 years ago
Yes could be a bad connection/burned wire or a blown control board.
ian33
#5 Posted : 12 years ago
ian33
Ok i checked the fuse and am coming up with 0 ohm
#6 Posted : 12 years ago
If the wiring to the broil element checks out OK then I would replace the control board.
ian33
#7 Posted : 12 years ago
ian33
Alright so just for my sanity i ordered and installed a new fuse still nothing. Should i pay someone to come out or just order a new control board hoping that works
#8 Posted : 12 years ago
Do what you feel comfortable with.
Personally I would just get the board but you have to go with your gut.
If you order the board from AppliancePartsPros you can return it if it does not fix the problem. See their return policy.
ian33
#9 Posted : 12 years ago
ian33
Yeah i order the panel this afternoon. Thanks for your help. Local company would have wanted $150 flat rate than a board was over $400
