ian33
#1 Posted : Sunday, September 16, 2012 4:28:37 PM(UTC)
ian33
Hey everyone I am in desperate need of some incite. My Broiler is not functioning at all on my range. No fault codes appear. I bought a new broiler element and that has not fixed the issue. Any help would be greatly appreciated!! The model is RF263LXTT1
cheers
Ian
#2 Posted : Tuesday, September 18, 2012 2:18:53 AM(UTC)
Replacement parts for Whirlpool RF263LXTT1 30" ELECTRIC FREESTANDING SELF CLEAN RANGE | AppliancePartsPros.com
The thermal fuse (Item 17 in Section 1) may have blown. It kills power to the broil element.
Un[plug the unit and one wire from the fuse and check it with a meter. Should be 0 ohms.
ian33
#3 Posted : Tuesday, September 18, 2012 9:53:30 AM(UTC)
ian33
Thanks i shall check that tonight! Are there any other possibilites?
#4 Posted : Tuesday, September 18, 2012 10:42:44 AM(UTC)
Yes could be a bad connection/burned wire or a blown control board.
ian33
#5 Posted : Tuesday, September 18, 2012 3:54:33 PM(UTC)
ian33
Ok i checked the fuse and am coming up with 0 ohm
#6 Posted : Wednesday, September 19, 2012 2:51:41 AM(UTC)
If the wiring to the broil element checks out OK then I would replace the control board.
ian33
#7 Posted : Tuesday, September 25, 2012 9:01:04 AM(UTC)
ian33
Alright so just for my sanity i ordered and installed a new fuse still nothing. Should i pay someone to come out or just order a new control board hoping that works
#8 Posted : Tuesday, September 25, 2012 1:59:57 PM(UTC)
Do what you feel comfortable with.
Personally I would just get the board but you have to go with your gut.
If you order the board from AppliancePartsPros you can return it if it does not fix the problem. See their return policy.
ian33
#9 Posted : Tuesday, September 25, 2012 2:11:34 PM(UTC)
ian33
Yeah i order the panel this afternoon. Thanks for your help. Local company would have wanted $150 flat rate than a board was over $400
Guest (4)
