Hey everyone I am in desperate need of some incite. My Broiler is not functioning at all on my range. No fault codes appear. I bought a new broiler element and that has not fixed the issue. Any help would be greatly appreciated!! The model is RF263LXTT1
cheers Ian
THIS FORUM IS DEAD!!!!!!! |
Thanks i shall check that tonight! Are there any other possibilites?
Yes could be a bad connection/burned wire or a blown control board. |
Ok i checked the fuse and am coming up with 0 ohm
If the wiring to the broil element checks out OK then I would replace the control board. |
Alright so just for my sanity i ordered and installed a new fuse still nothing. Should i pay someone to come out or just order a new control board hoping that works
Do what you feel comfortable with.
Personally I would just get the board but you have to go with your gut.
If you order the board from AppliancePartsPros you can return it if it does not fix the problem. See their return policy. |
Yeah i order the panel this afternoon. Thanks for your help. Local company would have wanted $150 flat rate than a board was over $400
