ValpoMan
#1 Posted : Monday, September 17, 2012 3:34:11 PM(UTC)
ValpoMan
Replaced the coils 2 years ago...working great since..last week wife mentioned that the dryer is not producing any heat...checked the peep hole and see no light at all....
Took the back off of the dryer and checked the Thermal Fuse with the meter....shows OPEN....so that is one part I ordered today....after reading on here that it suggested that the cycle thermostat is replaced at the same time I also ordered that part from the AppliancePartsPros....while I am waiting for the parts I cleaned the dryer out...also took the time to clean the pipe leading to outside...very dirty....believe that may have been the cause of my problem...
Question...I just took out the cycle thermostat and tested it for continuity...I do get numbers when touching the top and bottom contact on the thermostat....I get a OPEN when touching the left and right contact....does this mean the thermostat is in fact bad?
Also if I replace these parts and it still doesn't produce heat what should the next thing I look at?
MANY THANKS!
ValpoMan
Simon / APP Team
#2 Posted : Monday, September 17, 2012 3:58:10 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I don't thing there are more problems that open thermal fuse.
You should read continuity between large contacts of the cycling thermostat. To read the heating coil resistance set your meter to 10 Kohm.
Post the results.
Simon.
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Whirlpool Dryer Not Heating (Dryer Repair)
by Frustrated42 11/8/2015 7:21:05 AM(UTC)
by handygirl67 3/12/2015 1:14:03 PM(UTC)
whirlpool dryer not heating nor timer advancing (Dryer Repair)
by bladrnr 12/26/2013 12:39:41 PM(UTC)
electric whirlpool dryer not heating up (Dryer Repair)
by jumpnchuck 10/30/2013 6:31:51 PM(UTC)
Whirlpool Dryer not heating (Dryer Repair)
by cindystarr 9/28/2012 2:57:39 PM(UTC)
Whirlpool dryer not heating or turning (Dryer Repair)
by splumer 9/22/2012 10:05:44 AM(UTC)
by rdmousaw 8/7/2012 1:03:50 PM(UTC)
Whirlpool dryer not heating up (Dryer Repair)
by MKrieck 7/22/2012 6:37:03 PM(UTC)
Whirlpool Dryer not heating well (Dryer Repair)
by rockettme 6/7/2012 9:22:08 AM(UTC)
by moorece8 5/9/2012 5:28:21 AM(UTC)
Whirlpool Dryer Not heating up (Dryer Repair)
by rrussell@erols.com 4/25/2012 12:18:22 PM(UTC)
by Phiphtie 1/4/2012 3:09:19 PM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
by scoffman1234 3/16/2011 1:36:37 PM(UTC)
