amber8189
#1 Posted : Thursday, July 12, 2012 12:42:01 AM(UTC)
amber8189
Hello, I'm having problem with my Whirlpool Estate washer water level not filling up in order for the washer to start spinning. Can you help me out with a solution to the problem.
amber8189
#2 Posted : Thursday, July 12, 2012 12:45:34 AM(UTC)
amber8189
Originally Posted by: amber8189 Go to Quoted Post
Hello, I'm having problem with my Whirlpool Estate washer water level not filling up in order for the washer to start spinning. Can you help me out with a solution to the problem?
Do you think it could be the switch?
amber8189
#3 Posted : Thursday, July 12, 2012 12:49:40 AM(UTC)
amber8189
I'm having a problem with my Whirlpool Estate Washer. I loaded the washer with my clothing and the water level is not rising to where it's suppose to be in order for the washer to start spinning. Do you have a solution to what's causing this problem? Could it be the swith needs replacing or is the washer off balance? I'm in desperate need of anyone's help... Thank u!
Whirlpool Estate washer ETW4400WQ1 spins but won't drain (Washer Repair)
by ramchaza 4/17/2014 6:36:36 PM(UTC)
Whirlpool Estate washer fills then stops (Washer Repair)
by Kcburris 9/24/2013 6:33:25 PM(UTC)
Whirlpool Estate Washer won't Spin (Washer Repair)
by AnaBanana413 2/18/2013 11:24:14 AM(UTC)
Whirlpool Estate Washer (Washer Repair)
by Mikefaz 12/20/2011 11:46:18 AM(UTC)
Whirlpool Estate Washer Problem (Washer Repair)
by Peasaint 12/5/2011 1:29:46 PM(UTC)
Whirlpool Estate washer runs but doesn't agitate or drain (Washer Repair)
by torqhead 11/22/2010 8:42:39 AM(UTC)
whirlpool estate washer (Washer Repair)
by bestbet 7/28/2010 10:07:18 AM(UTC)
whirlpool estate washer wont spinout water (Washer Repair)
by itsmelatricia 2/14/2010 6:58:03 PM(UTC)
whirlpool estate washer only fills (Washer Repair)
by jakeman 8/8/2008 8:57:06 AM(UTC)
