AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool Estate washer ETW4400WQ1 spins but won't drain
It does everything right, spins but the water doesn't drain out. checked water hose and doesn't seem clogged.
Groups: Expert
Pump is directly attached to one end of motor shaft. When motor is running in spin direction, pump is running in pumpout direction. Either the pump is faulty, drain hoses are clogged or clothing is blocking the drain exit hole at bottom of outer tub (clothing between tubs).
Eric
Washer Repair
