ctstein
#1 Posted : Monday, July 9, 2012 1:23:56 PM(UTC)
ctstein
The dishwasher was working fine.
I hadn't used it in awhile and now I close the door and press the button.
No lights, No Power.
We did the reset. Turned breaker off for a day. It did not fix it.
We tested the fuse. That is fine. Power going in and out, at least 125 volts
Tested the door switch. That is fine. Power going in and out, at least 125 volts
There is power going into the circuit board. It doesn't come out.
What else should we test?
Thanks,
Alex
#2 Posted : Tuesday, July 10, 2012 12:51:38 PM(UTC)
Hi Alex,
The model number you posted is incomplete. Verify and repost it please.
ctstein
#3 Posted : Tuesday, July 10, 2012 12:58:55 PM(UTC)
ctstein
Model KUDS03CTSS3
#4 Posted : Tuesday, July 10, 2012 3:11:33 PM(UTC)
Most likely the problem is a bad control board.
Perform the "Checking keypad operation" test as described in the attached Tech sheet. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool KUDS03CTSS3 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
File Attachment(s):
Tech Sheet - W10130990 - KUDS03CTSS3.pdf (252kb) downloaded 15 time(s).
Whirlpool Dishwasher has no power and there is water in bottom (Dishwasher Repair)
by Tracies12 1/27/2018 10:20:44 AM(UTC)
Kitchenaide dishwasher has no power. voltage and fuse is good (Dishwasher Repair)
by rnorton61 9/11/2014 3:45:57 PM(UTC)
Whirpool Dishwasher has no power (Dishwasher Repair)
by Hard_Hat 6/16/2014 8:48:26 AM(UTC)
whirlpool dishwasher has no power (Dishwasher Repair)
by tprpap@cox.net 1/24/2013 8:12:30 PM(UTC)
dishwasher has no power after lightning storm (Dishwasher Repair)
by vbcoots 8/10/2012 9:14:46 AM(UTC)
kitchen aid dishwasher has no power (Dishwasher Repair)
by wisdom865 6/20/2012 9:47:37 AM(UTC)
KA dishwasher has no power but breaker is working (Dishwasher Repair)
by ldow 4/8/2010 3:57:49 AM(UTC)
whirlpool gu2548xtpq6 dishwasher has no power (Dishwasher Repair)
by nerocentric 1/23/2010 11:58:05 AM(UTC)
by clark1994 10/16/2009 5:53:46 PM(UTC)
Brand new Dishwasher has no power (Dishwasher Repair)
by Ozweego 9/16/2009 9:38:07 AM(UTC)
dishwasher has no power but rest of kitchen does (Dishwasher Repair)
by pandora 4/29/2009 5:03:20 PM(UTC)
Whirlpool dishwasher has no power lights (Dishwasher Repair)
by rrusbibste 3/3/2008 5:57:58 PM(UTC)
