The dishwasher was working fine. I hadn't used it in awhile and now I close the door and press the button. No lights, No Power.
We did the reset. Turned breaker off for a day. It did not fix it. We tested the fuse. That is fine. Power going in and out, at least 125 volts Tested the door switch. That is fine. Power going in and out, at least 125 volts
There is power going into the circuit board. It doesn't come out.
What else should we test?
Thanks, Alex
Hi Alex,
The model number you posted is incomplete. Verify and repost it please.
