clark1994
#1 Posted : Friday, October 16, 2009 5:53:46 PM(UTC)
clark1994
I am really struggling. My dishwasher quit working a few days ago so I took the door panel off and saw the door switch had went bad. So I went to the local appliance store and just bought the switch itself that went bad. After I replaced it I was able to wash 1 load and it quit again. This time I bought the door switch kit with the new leads and hooked it up and still nothing. Does anyone please have any idea what could be wrong now? I have power coming to the outlet, but that is all I know.
#2 Posted : Saturday, October 17, 2009 3:42:01 AM(UTC)
Replacement parts for WHIRLPOOL DU930PWPQ2 | AppliancePartsPros.com
Check the fuse Item 4 in the "Frame and console" section.
This may also help
http://www.servicematters.com/d...0Sheet%20-%208535431.pdf
Whirpool Dishwasher has no power (Dishwasher Repair)
by Hard_Hat 6/16/2014 8:48:26 AM(UTC)
