ernesto196484
#1 Posted : Sunday, March 29, 2009 7:45:37 PM(UTC)
ernesto196484
hi,
i have a GE model xl44 gas range (1996) that until recently has always worked good. suddenly the oven quit working on it. It is in pretty good shape yet and would'nt mind keeping it until i find a different one. also would like to fix it if possible so that i may be able to donate it as a working stove to someone in need. any ideas?
GE gas range oven won’t come on (Oven Repair (including Ranges and Cooktops))
by Guest 6/6/2021 3:02:24 PM(UTC)
F2 Error on GE Gas Range Model JGBP33SEH1SS (Oven Repair (including Ranges and Cooktops))
by dbevevino 6/15/2019 7:03:57 AM(UTC)
GE Gas Range Faulty Temp Readings and Slow to Heat (Oven Repair (including Ranges and Cooktops))
by yotimbo 2/9/2016 7:46:12 PM(UTC)
GE Gas range:XL44 - How to open sealed unit (Oven Repair (including Ranges and Cooktops))
by Jim Silvius 10/31/2012 12:02:04 PM(UTC)
Auto igniter not working on GE gas range (Oven Repair (including Ranges and Cooktops))
by saiprasad 6/28/2012 4:36:35 PM(UTC)
GE gas range (slide in) oven repair (Oven Repair (including Ranges and Cooktops))
by catinthehat 12/26/2011 10:13:16 AM(UTC)
GE Gas Range not holding temp (Oven Repair (including Ranges and Cooktops))
by Chance69 8/12/2011 9:24:40 AM(UTC)
GE Gas Range not holding temperature (Oven Repair (including Ranges and Cooktops))
by dfriend 2/23/2010 8:11:35 AM(UTC)
Burned insulation on igniter wires - GE gas range (Oven Repair (including Ranges and Cooktops))
by pbillow 1/31/2010 11:17:12 AM(UTC)
Maytage Gas Range - 2 Left Burners Won't Ignite - Have Spark (Oven Repair (including Ranges and Cooktops))
by boiler7904 9/28/2009 4:34:11 PM(UTC)
GE Gas Range Broiler will not shut off (Oven Repair (including Ranges and Cooktops))
by korybw 8/14/2009 8:21:55 AM(UTC)
Ge Gas Range Popped Circuit Breaker (Oven Repair (including Ranges and Cooktops))
by SFCHAMP97 6/5/2009 5:46:40 PM(UTC)
GE Gas Range diagnose ignite problem (Oven Repair (including Ranges and Cooktops))
by jonhunt 4/28/2009 9:37:12 AM(UTC)
by williamhaid 4/26/2009 2:10:48 PM(UTC)
GE gas range oven (Oven Repair (including Ranges and Cooktops))
by gdpifer 4/26/2009 7:53:06 AM(UTC)
