dickeydew
#1 Posted : Sunday, March 29, 2009 9:10:27 AM(UTC)
dickeydew
bought a heating element for my dryer but it still blows cold air . Is there anything else it could be.
#2 Posted : Sunday, March 29, 2009 1:13:11 PM(UTC)
The first thing I would do is check the circuit breakers for the dryer and make sure there is 240 VAC at the wall outlet.
If there is nothing wrong then perform the troubleshooting as described in one of our previous posts: http://forum.appliancepartspros...timer-wont-turn-off.html
Here are the break down diagrams and Replacement parts for WHIRLPOOL REX6634RQ1 | AppliancePartsPros.com
Roper Dryer RES7745PQ0 (Dryer Repair)
by ARC575 4/19/2020 3:58:45 PM(UTC)
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 1/4/2017 5:45:40 PM(UTC)
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 1/2/2017 9:15:02 AM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 9/11/2015 4:59:42 PM(UTC)
roper dryer (Dryer Repair)
by smoke-71 3/3/2015 3:56:21 AM(UTC)
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 1/7/2015 8:50:40 AM(UTC)
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
