williamsonm
#1 Posted : Tuesday, March 24, 2009 3:16:13 PM(UTC)
williamsonm
Oven just started staying hot....noticed it yesterday. No lights indicate that it is on, knob is turned off. Any ideas? Hoping I won't have to buy a new one.....well, ok, a new one would be nice, but don't want to spend the money if I don't have to.....:)
#2 Posted : Wednesday, March 25, 2009 2:40:48 AM(UTC)
Sounds like either the broil or bake relay contacts are welded together.
I believe they are on the control\time board
Also may be that a wire is shorting to the frame, will have to open it up and check for this.
Remember to unplug the unit, it is 240 volts so is very dangerous.
Here is the control board, see the note.
Part Details - GE To8 control, part number: WB50T10044
Oven will not turn off (Oven Repair (including Ranges and Cooktops))
by fire51 7/27/2012 12:24:34 PM(UTC)
oven will not turn off (Oven Repair (including Ranges and Cooktops))
by goblue5810 1/6/2012 4:10:05 PM(UTC)
Wall oven will not turn off (Oven Repair (including Ranges and Cooktops))
by berjr 3/31/2010 4:38:33 AM(UTC)
by dhexamer 3/24/2010 10:44:19 AM(UTC)
by cory seiler 12/6/2009 12:38:52 PM(UTC)
Maytag Stove/Oven - oven will not turn off (Oven Repair (including Ranges and Cooktops))
by bodnarja 9/29/2009 4:23:39 PM(UTC)
Frigidaire oven will not turn off (Oven Repair (including Ranges and Cooktops))
by pkelly 5/30/2009 12:51:19 PM(UTC)
Jenn-Air oven will not turn off (Oven Repair (including Ranges and Cooktops))
by teegee 3/13/2009 1:56:52 PM(UTC)
Oven Will Not Turn Off!?! (Oven Repair (including Ranges and Cooktops))
by millerm77 2/8/2009 4:49:55 PM(UTC)
Top coil in oven will not turn off (Oven Repair (including Ranges and Cooktops))
by kkozara 11/28/2008 6:45:15 AM(UTC)
by lbrown 10/24/2007 6:19:42 PM(UTC)
