dhexamer
#1 Posted : Wednesday, March 24, 2010 10:44:19 AM(UTC)
dhexamer
Oven stays on all the time. When you cut the power, turn the power back on, the oven is still on and error code is PF for power failure. When you reset the Pf button the PF error code stops but the oven is still on. Is this a circuit board failure or keypad failure or both? How do you test to find out which one or both?
magician59
#2 Posted : Wednesday, March 24, 2010 11:32:03 AM(UTC)
magician59
this sounds oike acontrol board issue. Part number: AP3851248
Oven will not turn off (Oven Repair (including Ranges and Cooktops))
by fire51 7/27/2012 12:24:34 PM(UTC)
oven will not turn off (Oven Repair (including Ranges and Cooktops))
by goblue5810 1/6/2012 4:10:05 PM(UTC)
Wall oven will not turn off (Oven Repair (including Ranges and Cooktops))
by berjr 3/31/2010 4:38:33 AM(UTC)
by cory seiler 12/6/2009 12:38:52 PM(UTC)
Maytag Stove/Oven - oven will not turn off (Oven Repair (including Ranges and Cooktops))
by bodnarja 9/29/2009 4:23:39 PM(UTC)
Frigidaire oven will not turn off (Oven Repair (including Ranges and Cooktops))
by pkelly 5/30/2009 12:51:19 PM(UTC)
by williamsonm 3/24/2009 3:16:13 PM(UTC)
Jenn-Air oven will not turn off (Oven Repair (including Ranges and Cooktops))
by teegee 3/13/2009 1:56:52 PM(UTC)
Oven Will Not Turn Off!?! (Oven Repair (including Ranges and Cooktops))
by millerm77 2/8/2009 4:49:55 PM(UTC)
Top coil in oven will not turn off (Oven Repair (including Ranges and Cooktops))
by kkozara 11/28/2008 6:45:15 AM(UTC)
by lbrown 10/24/2007 6:19:42 PM(UTC)
