Cindy Schneider
#1 Posted : Monday, February 13, 2012 10:54:21 AM(UTC)
Cindy Schneider
I want to replace the ice maker but I want to make sure thats really the problem. It seems it ought to be at the base of the refrigerator where the line feeds into the motor. If so can this be fixed?
#2 Posted : Monday, February 13, 2012 3:01:11 PM(UTC)
Cindy,
What exactly is wrong?
The model number you posted is incorrect. Verify and repost it please.
Cindy Schneider
#3 Posted : Tuesday, February 14, 2012 6:56:17 PM(UTC)
Cindy Schneider
Cindy,
Gene, The refrigerator Model No. is HMG 191300, Admiral Designer Series purchased in 2000. The Ice Maker Model No. is not noted on the equipment, but inside the refrigerator it says use Ice Maker HMG 901400. It worked fine until about six months ago when it stopped making ice. I believe the water stopped filling the compartment.
Cindy
#4 Posted : Thursday, February 16, 2012 12:57:30 PM(UTC)
Cindy,
The following is the ice maker kit recommended for your refrigerator. The kit includes the water valve as well. If you do not have a water filter installed yet I would recommend to do it too.
- The ice maker kit Part number: AP4261368
- The inline water filter Part number: AP3109540
- The water line Part number: AP4494519
Cindy Schneider
#5 Posted : Sunday, February 19, 2012 7:02:01 PM(UTC)
Cindy Schneider
I have replaced the lines. The ice maker is reconnected and it seems to be turning. There is no water. So if there is no water being pumped from the bottom could there be a motor in back of the refrig thats not pumping the water up? I think I need to replace this next. Thoughts?
Cindy Schneider
#6 Posted : Tuesday, February 21, 2012 1:02:41 PM(UTC)
The problem can be a bad water inlet valve on the back of the refrigerator (can be tested for continuity) or a bad ice maker (if it does not send proper signal to the water inlet valve).
- The water inlet valve Part number: AP3961809
Guest (4)
Whirlpool Model WRS588FIHZ00 Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by roma1625 7/23/2022 4:39:02 AM(UTC)
GE Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by Jyet2001 4/22/2016 1:12:45 PM(UTC)
Ice maker stopped working... (Refrigerator & Freezer Repair)
by Steelwheels1 4/6/2015 3:51:42 AM(UTC)
Ice maker stopped working on Kitchenaid (Refrigerator & Freezer Repair)
by schroederius 3/20/2013 9:23:17 AM(UTC)
by ACHASG 4/23/2012 8:43:17 AM(UTC)
by wrexpert 2/15/2011 5:23:29 PM(UTC)
Control Panel, Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by jrymski 2/13/2011 6:44:09 PM(UTC)
Ice maker stopped working. (Refrigerator & Freezer Repair)
by HomerH209 11/9/2010 10:50:59 AM(UTC)
Amana Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by smaggard 9/27/2010 1:40:00 PM(UTC)
Maytag French Door ice maker stopped working (Refrigerator & Freezer Repair)
by kayken1010 8/3/2010 2:26:40 AM(UTC)
by dmkimm 7/21/2010 7:21:06 AM(UTC)
Kitchenaid side by side ice maker stopped working (Refrigerator & Freezer Repair)
by aloubo 2/19/2010 3:52:41 AM(UTC)
ice maker stopped working - kenmore elite side by side (Refrigerator & Freezer Repair)
by foobydoo 1/26/2010 1:12:14 PM(UTC)
GE Adora Fridge: Ice Maker stopped working. (Refrigerator & Freezer Repair)
by lighthouse832 1/7/2010 12:50:11 PM(UTC)
by Ken Jordan 12/23/2009 4:59:21 PM(UTC)
