mamaof3pinks
#1 Posted : Thursday, February 26, 2009 6:42:32 AM(UTC)
mamaof3pinks
My washer is leaking water but not too much which has started about a week and am anxious to get it fix or get another one.. My washer basket seems to hit around the sides during spinning and when it started fillin up while hte basket is slowing down from spinning, i have caught the that basket is not stayin where the water is filling in and beleive that is what causes the leaks. My husband checked the hoses and eveyrthing else. So it seems that the washer basket is very loose. what is that i can do to fix it and what part is it?:confused:
TechnicianBrian
#2 Posted : Thursday, February 26, 2009 12:07:42 PM(UTC)
TechnicianBrian
Check the balance spring (AP2906091) and make sure it is still attached from the rear of the basket to the base plate. If it breaks or comes loose, the basket will lean forward due to the weight of the motor and yes, water will leak out the back when it fills after a spin cycle.
Kenmore Series 80 washer leaking water above clutch assembly (Washer Repair)
by hallway 2/5/2017 1:48:24 PM(UTC)
Kenmore washer leaking water on transmission (Washer Repair)
by arttruji 6/30/2016 11:55:27 AM(UTC)
washer leaking water when washing front door (Washer Repair)
by OMAR MARTINEZ 8/13/2014 1:16:58 PM(UTC)
kitchenaid dishwasher leaking water from door (Dishwasher Repair)
by brasuca 1/20/2014 9:55:31 AM(UTC)
GE front load washer leaking water at the back of the drum. (Washer Repair)
by Ooltewah 10/13/2012 12:17:32 PM(UTC)
washer leaking water through transmission (Washer Repair)
by hessians1 1/16/2012 12:02:57 PM(UTC)
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 11/21/2011 8:55:22 AM(UTC)
Dishwasher leaking water from motor area (Dishwasher Repair)
by thenefas 11/3/2010 8:25:52 PM(UTC)
Frigidaire Washer Leaking Water From Front (Washer Repair)
by sdsprigler 10/29/2010 10:27:04 AM(UTC)
Dishwasher leaking water through door (Dishwasher Repair)
by redcam80 5/8/2010 12:21:13 PM(UTC)
LG frontload washer leaking water during drain cycle (Washer Repair)
by bluefitness 1/20/2010 10:38:16 AM(UTC)
washer leaking water from bottom (Washer Repair)
by gricodrywall 12/28/2009 1:41:27 AM(UTC)
Samsung washer leaking water (Washer Repair)
by lflamenco98 9/2/2009 11:30:59 AM(UTC)
Dishwasher Leaking Water (Dishwasher Repair)
by jlehn 6/26/2009 7:41:16 AM(UTC)
washer leaking water and oil or grease on the floor under it (Washer Repair)
by asnowangel2000 4/12/2009 3:47:01 PM(UTC)
