AppliancePartsPros.com
Appliance Repair Help
Washer Repair
LG frontload washer leaking water during drain cycle
LG wm2688hwm
My LG frontload washer started leaking towards the end of the cycle. I tried to duplicate the leak and ran it a few times, but it did not leak. I'm guessing it started leaking during the drain cycle. Is there anything I should check? I pulled the filter assembly in the front. It didn't have any media in it. I'm not sure if it supposed to, or it is just supposed to be a plastic screen. I appreciate any and all help.
Thank you
It looks like it was leaking during the spin cycle. The water was coming out of the air vent pip out of the back of the unit. I cleaned the stopper that is supposed to prevent water from coming out during the spin cycle. I also heard that this problem can be caused by using regular detergent instead of he. Is there anything else I should look for?
Washer Repair
