bluefitness
#1 Posted : Wednesday, January 20, 2010 10:38:16 AM(UTC)
bluefitness
LG wm2688hwm
My LG frontload washer started leaking towards the end of the cycle. I tried to duplicate the leak and ran it a few times, but it did not leak. I'm guessing it started leaking during the drain cycle. Is there anything I should check? I pulled the filter assembly in the front. It didn't have any media in it. I'm not sure if it supposed to, or it is just supposed to be a plastic screen. I appreciate any and all help.
Thank you
bluefitness
#2 Posted : Thursday, January 21, 2010 10:13:23 AM(UTC)
bluefitness
It looks like it was leaking during the spin cycle. The water was coming out of the air vent pip out of the back of the unit. I cleaned the stopper that is supposed to prevent water from coming out during the spin cycle. I also heard that this problem can be caused by using regular detergent instead of he. Is there anything else I should look for?
