tim h
#1 Posted : Friday, November 16, 2007 10:20:16 AM(UTC)
tim h
My dishwasher is making a "growling" noise when washing. It doesn't always do it. it almost sounds like plastic gears that are not meshing
properly. Any ideas what is causing this? :confused:
#2 Posted : Friday, November 16, 2007 12:23:36 PM(UTC)
I need you to monitor the dishwasher to verify if it makes that noise when it fills up with water or when the wash pump is running.
tim h
#3 Posted : Friday, November 16, 2007 1:27:14 PM(UTC)
tim h
It only makes the noise when the dishwasher is full of water and the pump is running.
#4 Posted : Friday, November 16, 2007 2:45:03 PM(UTC)
In that case, most likely there is a foreign object inside the pump goes through the grinder. It should stop as soon as it'll go through.
How old is the dishwasher?
If it's less then 2 years, it's still under the manufacturer warranty.
tim h
#5 Posted : Saturday, November 17, 2007 8:42:23 AM(UTC)
tim h
It is only 5 months past warranty. what is the procedure to get to the foreign object in the pump?
Jus' Plain Bob
#6 Posted : Wednesday, June 30, 2010 1:10:59 PM(UTC)
Jus' Plain Bob
Had the same problem. Found the fix here:
http://www.fixya.com/support/t233507-noisy_dishwasher
Seems the problem is the water pipe that feeds the upper rack rotating sprayer. Usually a clip broken that secures the pipe to the bottom of the upper rack. I fixed mine with a plastic wire-bundle tie that can't rust. Hope this helps!
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
GE Dishwasher noise (Dishwasher Repair)
by bhorvath7666 9/13/2015 7:29:12 AM(UTC)
dishwasher noise while washing (Dishwasher Repair)
by mpickell 2/27/2015 7:10:27 PM(UTC)
by Duaine 1/30/2011 9:10:16 AM(UTC)
by softail96 1/22/2010 2:16:19 PM(UTC)
Whirlpool Quiet Partner IV Dishwasher noise (Dishwasher Repair)
by 123POW 10/16/2009 10:28:55 AM(UTC)
by Robert Barker 5/8/2009 9:02:11 AM(UTC)
Kitchaid dishwasher noise and then leak (Dishwasher Repair)
by ara 3/9/2009 5:16:02 PM(UTC)
Dishwasher Noise (Dishwasher Repair)
by apptom 1/2/2009 3:57:45 PM(UTC)
bosch dishwasher noise; still cleans (Dishwasher Repair)
by cjc 11/30/2008 6:33:49 AM(UTC)
Bosch dishwasher noise (Dishwasher Repair)
by leweemagoo 11/24/2008 5:38:12 PM(UTC)
Dishwasher noisey, and dishes come out dirtier than before they are washed. (Dishwasher Repair)
by jayjay25 8/19/2008 1:47:45 AM(UTC)
Admiral dishwasher noise (Dishwasher Repair)
by repair man 4/7/2008 2:05:44 PM(UTC)
Bosh Dishwasher noise (Dishwasher Repair)
by phayburnsr 12/20/2007 12:34:08 PM(UTC)
Dishwasher noise and no water (Dishwasher Repair)
by ferfer 11/16/2007 4:03:39 PM(UTC)
