I have an admiral dishwasher makeing a lot of noise when i first start and at the point of dumping water . Thought it might be comeing from main motor but am starting to wonder if it is comeing from drain pump. Pulled drain pump apart and did not see anything in it or loose. Tryed to pull main motor out takeing the 5 screws out of the lower water spinner and than a single screw that held in a small water circulater and them the three screws under the main motor but was unable to still get the pump out. Boy do i need some help!:(
After pulling the dish washer out a half dozen times i solved the problem . seems a small piece of plastic went thru the dish washer and was creating problems along the way.First at the motor which was causeing it to stop and them later at the pump. re moved THE PIECE LAST NIGHT AND ALL IS FINE.:D
