lindaa
#1 Posted : Thursday, December 8, 2011 3:39:17 PM(UTC)
lindaa
Haven't rec'd answer to "no hot water" qt.
We have switched the hot & cold hoses at the wall. When I push the hot control button, nothing happens. When I push the cold button, the hot water flows into the tub. Does that point to any part that might be broken? I called "parts" and they said there is no longer a "water selection switch" in stock. What do you think the prob. could be?
ApplianceJunk
#2 Posted : Thursday, December 8, 2011 3:55:12 PM(UTC)
ApplianceJunk
I would check it by testing for voltage at the water inlet valve and/or ohm out the water temp selector switch.
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
No hot water (Washer Repair)
by scv1 12/29/2015 7:41:39 PM(UTC)
by scv1 12/29/2015 7:39:54 PM(UTC)
No Hot Water Coming From Inlet Valve (Washer Repair)
by sophialh74 10/17/2014 5:37:11 AM(UTC)
No hot water in Maytag washer (Washer Repair)
by Pastaronie 8/16/2014 12:29:47 PM(UTC)
by arylisrandy 10/20/2013 1:35:09 PM(UTC)
No Hot Water in Washer (Washer Repair)
by Obuasi 2/8/2013 4:30:18 AM(UTC)
No Hot water (Washer Repair)
by jeschw 8/5/2012 6:19:05 AM(UTC)
No Hot Water Coming Into Washer (Washer Repair)
by chloed 2/7/2012 8:08:03 AM(UTC)
maytag washer no hot water (Washer Repair)
by lindaa 12/7/2011 11:18:26 AM(UTC)
Whirlpool dishwasher has no hot water or heat for drying (Dishwasher Repair)
by ford2953 6/27/2011 5:10:33 PM(UTC)
Whirlpool Washer - No Hot Water (Washer Repair)
by jeff mitchell 5/20/2011 8:43:32 PM(UTC)
by amayesin 4/30/2011 4:03:38 AM(UTC)
Frigidaire Washer - No Hot Water (Washer Repair)
by cdWJordan 4/8/2011 12:52:49 PM(UTC)
Bosch dishwasher no hot water (Dishwasher Repair)
by samsrc 2/15/2011 7:46:00 AM(UTC)
