Danrepair
#1 Posted : Thursday, December 1, 2011 8:24:57 AM(UTC)
Danrepair
Unusally loud spin cycle. Spins at what appears to be proper speed. |Loud whirring noise.
sidfink43
#2 Posted : Friday, December 2, 2011 4:28:46 PM(UTC)
sidfink43
I cannot get your model number to come up, it may be mssing a letter but if this is a Frigidaire front loader it is probably the rear tub bearing, which is not good news. The bearing is not a separate repair and you must replace the entire rear tub, which is an expensive proposition and usually means replacing the washer instead.
ApplianceJunk
#3 Posted : Friday, December 2, 2011 6:04:17 PM(UTC)
ApplianceJunk
If it is a front load open the door and give the basket a good spin by hand.
If you hear the noise when spinning it by hand that is a good sign that the bearing have failed.
GE Washer - Noisy Spin Cycle (Washer Repair)
by jbblack 6/22/2021 4:47:04 AM(UTC)
Whirlpool Calypso slow, noisy spin cycle (Washer Repair)
by supergm7 11/16/2015 4:22:13 PM(UTC)
Noisy Spin cycle (Washer Repair)
by JamesO 5/4/2013 2:29:37 PM(UTC)
Noisy spin cycle (Washer Repair)
by stellaweezy 5/4/2013 1:44:20 PM(UTC)
by justinw 12/16/2012 6:30:54 AM(UTC)
by minka1333 2/8/2012 11:25:38 AM(UTC)
by Dolly1 1/12/2012 4:15:09 PM(UTC)
Maytag Washer Noisy Spin Cycle and Agitate (Washer Repair)
by Joseph_igallegos 6/1/2011 3:32:44 PM(UTC)
by bgdadd 4/2/2011 9:35:54 AM(UTC)
by Paul March 4/1/2011 4:50:36 PM(UTC)
Noisy Spin Cycle on level machnie (Washer Repair)
by malibu3426 10/27/2010 9:22:09 PM(UTC)
Noisy Spin Cycle (Cabrio) (Washer Repair)
by tedbuck 9/22/2010 8:27:13 AM(UTC)
Front Load Frigidaire With Noisy Spin Cycle (Washer Repair)
by mb250c 7/6/2009 2:04:50 PM(UTC)
by ezonana1 1/31/2008 1:25:14 PM(UTC)
by psmith 12/9/2007 1:31:26 PM(UTC)
