Here is your parts breakdown includes wiring diagrams
Model SearchNote the wire on the right side of the MOTOR CENTrifugal Switch goes to L2.
It is just cut off on the diagram.
Your circuit path to start the motor is NEUTRAL , THERMAL FUSE , DOOR SWITCH C/NO , MOTOR's Run and AUX windings , MOMENTARY PUSH TO START switch , TIMER contacts M/L , L1
Fuse should be OK because the light works. This does not mean that the door contacts close when the door closes. Try manually closing it. Note also could be the contacts in the switch may be blown.
I would unplug the unit and use a meter to check the components.
If you do not have one I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
