My front load washer is 3 years old, but now it's stopped working at the middle-circle :(. I'll try to fix it. Can anyone help me with this? thanks
Originally Posted by: langkhach2013  My front load washer is 3 years old, but now it's stopped working at the middle-circle :(. I'll try to fix it. Can anyone help me with this? thanks Langkhach, If the washer is stopping mid cycle, your first check should be the cold water faucet, hose and fill valve Part number: AP3844429
If there's no cold water, the washer will stop at the rinse cycle. Then check the water level switch and wiring. Part number: AP4298882
There's a slight possibility it may have an intermittent circuit, or loose connection and not allowing the washer to fill or complete the circuit to run the motor.
