langkhach2013
#1 Posted : Monday, February 18, 2013 8:06:09 AM(UTC)
langkhach2013
My front load washer is 3 years old, but now it's stopped working at the middle-circle :(. I'll try to fix it. Can anyone help me with this? thanks
Joe / APP Team
#2 Posted : Monday, February 18, 2013 8:27:19 AM(UTC)
Joe / APP Team
Langkhach, If the washer is stopping mid cycle, your first check should be the cold water faucet, hose and fill valve
Part number: AP3844429
If there's no cold water, the washer will stop at the rinse cycle. Then check the water level switch and wiring.
Part number: AP4298882
There's a slight possibility it may have an intermittent circuit, or loose connection and not allowing the washer to fill or complete the circuit to run the motor.
