jose julio alves
#1 Posted : Tuesday, June 12, 2012 8:14:21 PM(UTC)
jose julio alves
dryer is in good condition. However, if I after I closed the door during cycle starts immediately The only ways it's stays off is with the door open. Do I need to replace the timer?
#2 Posted : Wednesday, June 13, 2012 1:00:55 AM(UTC)
A model number may help others help you.
Sounds like the start switch is shot (contacts welded together).
If it is part of the timer then I would replace the timer.
Guest (4)
