Sally A. Nathan
#1 Posted : Monday, January 19, 2009 10:26:30 AM(UTC)
Sally A. Nathan
I just received the generic infinite switch for my Amana range. On the back, under the word TOP, there are two prongs with L2 in the middle. On my original switch, there is only one wire L2. To which of the prongs do I attach the wire, the one on the right or the left?
Thank you for your help.
Saly
magician59
#2 Posted : Tuesday, January 20, 2009 8:43:30 AM(UTC)
magician59
Being generic, the terminals are probably interconnected. Test this with a continuity tester. Then, connect your L2 to the one that gives the best fit.
Sally A. Nathan
#3 Posted : Tuesday, January 20, 2009 10:50:53 AM(UTC)
Sally A. Nathan
Thank you for responding. What is a continuity tester and where would I find one?
magician59
#4 Posted : Tuesday, January 20, 2009 12:42:28 PM(UTC)
magician59
A continuity tester is a device that tests the continuity, or, electrical "soundness" of a conductor (anything that conducts electricity). A simple one can be improvised by connecting a light bulb from a flashlight to a length of wire (do this by wrapping the bare end of the wire around the threaded part of the bulb, and taping it in place); the other end of the wire to a couple batteries (taped end to end, as if in a flashlight). At the other end of the batteries, attach another length of wire. (The ends of the wires need to be bare, by the way). Now, if you place the tip of the light bulb onto one of the "L2" terminals, and the loose end of the second wire onto the other, the light will glow to show that the terminals are interconnected, or it will not glow, showing that they are not. If this sounds too much like a junior-high science project, you can buy an inexpensive continuity tester anywhere you can get electric parts (even Wal-Mart). NEVER (EVER) use a continuity tester on a Live circuit or component!
GE range replacing a infinite switch but need the wiring diagram (Oven Repair (including Ranges and Cooktops))
by jlsalazar101 1/24/2024 2:49:12 PM(UTC)
Jenn-Air stove top infinite switch clicking (Oven Repair (including Ranges and Cooktops))
by JonVahsholtz 11/15/2021 9:11:15 PM(UTC)
Whirlpool RF198LXMP0 range infinite switch issue (Oven Repair (including Ranges and Cooktops))
by Dan440 7/6/2021 12:28:18 PM(UTC)
Substitute Infinite switch (Oven Repair (including Ranges and Cooktops))
by Neil Scribner 2/19/2021 9:40:29 AM(UTC)
Whirlpool drop in infinite switch (Appliance Parts)
by dbeisner3@gmail.com 1/14/2019 9:09:25 AM(UTC)
Wiring for Dual Element Infinite Switch (Oven Repair (including Ranges and Cooktops))
by RollingSpinner 2/5/2018 11:48:21 AM(UTC)
Dual Infinite Switch Kit Wiring Questions (Oven Repair (including Ranges and Cooktops))
by mahjko 12/3/2013 7:22:50 AM(UTC)
Element or infinite switch? (Oven Repair (including Ranges and Cooktops))
by caroljac 10/29/2013 10:41:05 AM(UTC)
Infinite switch replacement (Oven Repair (including Ranges and Cooktops))
by J_T 9/14/2013 2:43:04 PM(UTC)
Infinite Switches are sparking (Oven Repair (including Ranges and Cooktops))
by bds120 8/14/2013 6:46:35 AM(UTC)
Thermador Infinite Switch Replacement (Oven Repair (including Ranges and Cooktops))
by JLondon 4/16/2013 2:17:18 PM(UTC)
Testing An Infinite Switch (Oven Repair (including Ranges and Cooktops))
by dmccollo 3/26/2013 12:32:50 PM(UTC)
Jenn Air Infinite Switch (Oven Repair (including Ranges and Cooktops))
by swfworldwide 11/27/2012 5:07:49 AM(UTC)
replace cooktop infinite switch (Oven Repair (including Ranges and Cooktops))
by stickyfingers 11/26/2012 8:36:45 AM(UTC)
Modifying Infinite switch AP4009110 (Oven Repair (including Ranges and Cooktops))
by NelsonSoto 9/26/2012 7:09:12 PM(UTC)
