mtcarmelfmly
#1 Posted : Sunday, January 11, 2009 3:46:06 PM(UTC)
mtcarmelfmly
My washer started a spin cycle where is was very off balanced. It was knocking the sides as I stopped it and repositioned the load and restarted it. When I restarted the washer it would no longer spin or agitate. I tried all the different cycles and spins and it will not do anything but, fill and empty. Nothing will move. We took the front off and the belt is fine. Any ideas?
Drags1998
#2 Posted : Sunday, January 11, 2009 3:50:29 PM(UTC)
Drags1998
Check the LID-SWITCH!!! It could have gotten bent from the POUNDING!!!:D
mtcarmelfmly
#3 Posted : Sunday, January 11, 2009 3:53:07 PM(UTC)
mtcarmelfmly
That makes sense. We will check that out! Thanks
mtcarmelfmly
#4 Posted : Sunday, January 11, 2009 4:01:02 PM(UTC)
mtcarmelfmly
YEAHHH!!! That was it! You are saved us a repair call! Thank you so much! It broke the little pin right off! Can I get a new one?
Drags1998
#5 Posted : Sunday, January 11, 2009 4:30:00 PM(UTC)
Drags1998
Should be able to order one from your nearest dealer!! Glad to help!!!!!!!!!:D
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
Estate Washer will not agitate or spin (Washer Repair)
by Greenday1827 7/19/2013 12:34:47 PM(UTC)
by mike145 6/25/2013 5:11:49 PM(UTC)
Kenmore washer will not agitate or spin (Washer Repair)
by dlacacres 5/8/2013 9:46:24 AM(UTC)
GE washer will not agitate or spin (Washer Repair)
by st smith 4/1/2013 7:11:12 AM(UTC)
Newer GE Washer will not agitate or spin (Washer Repair)
by dwolfe 9/11/2012 8:34:44 AM(UTC)
my washer will not agitate or spin (Washer Repair)
by angelsthree 5/3/2012 5:49:18 AM(UTC)
Maytag washer will not agitate or spin (Washer Repair)
by roscoepcoltrain 4/19/2012 4:55:32 AM(UTC)
Maytag Washer will not agitate or spin (Washer Repair)
by Mbat4 2/13/2012 3:12:24 PM(UTC)
by wpatetec 12/19/2011 4:45:27 PM(UTC)
Motor Hums But Washer Will Not Agitate Or Spin (Washer Repair)
by john@ljolson.com 10/22/2011 12:14:27 PM(UTC)
