muttnjeff
#1 Posted : Tuesday, August 30, 2011 12:59:50 PM(UTC)
muttnjeff
the freezer gets little cool the ice box does not,also no air blowing in the ice box,compressor and fan are running
#2 Posted : Wednesday, August 31, 2011 2:38:17 AM(UTC)
I am assuming by "ice box" you mean the fresh food side.
I would not worry about the fresh food side right now, it is the freezer that is important as all cooling originates here.
When you say the fan is running, do you mean the evaporator/freezer fan?
It must run for the unit tto cool properly.
Is the compressor cycling or on all the time?
If it is cycling then there is probably a thermostat problem.
Remove the cover in the freezer so you can inspect the evaporator coils.
If they are heavily frosted/iced over then you have a defrost problem.
If there is no frost or just frost in one area then it is probably a sealed system problem.
This test must be done after the unit has run continuously for a couple hours.
If you do it shortly after a defrost cycle then there of course will be no frost.
Here is a good link for basic fridge troubleshooting/repair info.
http://www.applianceaid.com/frig.html
Fridge / Freezer will not cool (Refrigerator & Freezer Repair)
by Billg58 2/19/2015 7:29:45 PM(UTC)
by kscssmm 7/19/2013 9:49:30 PM(UTC)
will not cool below 37 (Refrigerator & Freezer Repair)
by jtanthony 6/28/2013 3:54:29 PM(UTC)
Fridge and freezee will not cool (Refrigerator & Freezer Repair)
by Austin8214 6/11/2013 6:07:25 AM(UTC)
Refrigerator/Freezer will not cool. (Refrigerator & Freezer Repair)
by Leo3030 5/9/2013 5:31:35 AM(UTC)
Fridge will not cool (Refrigerator & Freezer Repair)
by cory82 4/21/2013 5:39:09 AM(UTC)
refrig will not cool and freezer will not freeze (Refrigerator & Freezer Repair)
by marykiefer 2/10/2013 4:44:35 PM(UTC)
Will not cool (Refrigerator & Freezer Repair)
by buggyman20 2/4/2013 9:37:59 AM(UTC)
Dryer will not cool down (Dryer Repair)
by renegade_7 4/8/2012 5:20:01 PM(UTC)
Refrigerator & Freezer will not cool after move (Refrigerator & Freezer Repair)
by divalyri 3/28/2012 9:34:03 AM(UTC)
Kenmore Refrigerator will Not Cool (Refrigerator & Freezer Repair)
by bradform 2/23/2012 10:27:12 AM(UTC)
top shelves in fridge and freezer will not cool (Refrigerator & Freezer Repair)
by linda1971 7/24/2011 8:18:52 AM(UTC)
Whirlpool side by side will not cool both sides (Refrigerator & Freezer Repair)
by Redwings 1/17/2011 9:32:34 AM(UTC)
Refridgerator will not cool and freezer wont freeze (Refrigerator & Freezer Repair)
by bpbuba711 12/10/2010 3:21:57 PM(UTC)
maytag electric dryer will not cool down (Dryer Repair)
by Ingo 11/9/2010 7:28:00 AM(UTC)
