linda kolonsky
#1 Posted : Thursday, July 28, 2011 4:46:24 PM(UTC)
linda kolonsky
simple question - have received both bake/broil elements - ready to install - have turned off circuit breakers and stove does not work - cannot get to the plug on the stove without pulling it out - cannot move this stove - is it safe to work on it with just the circuit breakers set to off?
#2 Posted : Friday, July 29, 2011 3:47:13 AM(UTC)
[COLOR="DarkRed"]is it safe to work on it with just the circuit breakers set to off?[/COLOR]
I doubt anyone will answer this because if the wiring is not done correctly then it is not safe.
So if someone says yes and you electrocute yourself then a lawyer might be after that someone.
So all I can say is that it could be.
Also if both elements went out at the same time then I doubt it is an element problem as the odds of them both failing at the same time is slim to say the least.
You did not include a model number so I have no idea what type of unit this is.
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
GE Electric Range - nothing heats (oven or burners) (Oven Repair (including Ranges and Cooktops))
by tgtn7723 11/29/2020 5:29:31 AM(UTC)
GE Electric Range not maintaining temperature. (Oven Repair (including Ranges and Cooktops))
by Flicker87 11/24/2015 7:53:57 PM(UTC)
Really old GE electric range... HELP (Oven Repair (including Ranges and Cooktops))
by pinkimarie 12/3/2013 2:27:48 PM(UTC)
GE Electric Range, Oven (Oven Repair (including Ranges and Cooktops))
by Hanne555 4/28/2013 5:24:50 AM(UTC)
GE Electric Range - Display/oven clicks, cuts on and off. (Oven Repair (including Ranges and Cooktops))
by GeorgePo 12/27/2012 3:17:30 PM(UTC)
GE electric range top shorted out (Oven Repair (including Ranges and Cooktops))
by brizander 9/12/2012 2:22:52 PM(UTC)
1960's GE Electric Range 4-connector elements (Oven Repair (including Ranges and Cooktops))
by billca 8/13/2012 12:55:44 PM(UTC)
GE electric range (Oven Repair (including Ranges and Cooktops))
by CHIEF1096 9/2/2011 11:24:56 AM(UTC)
GE Electric Range Part (Oven Repair (including Ranges and Cooktops))
by MDHome 1/29/2011 7:28:10 AM(UTC)
GE Electric Range won't get hot unless you turn it way up (Oven Repair (including Ranges and Cooktops))
by axrowland 1/10/2010 7:46:45 PM(UTC)
Replacing insulation in GE electric range/oven (Oven Repair (including Ranges and Cooktops))
by JudgeHooke 1/4/2010 1:23:24 PM(UTC)
GE electric range thermostat replacement (Oven Repair (including Ranges and Cooktops))
by Arnie 3/18/2009 8:38:23 AM(UTC)
GE Electric Range (Oven Repair (including Ranges and Cooktops))
by DRWALLIE 3/15/2009 6:20:28 PM(UTC)
