Two days ago, my dryer quit heating. I took the back off and checked for continuity on the thermal fuses - I am an electrician. I discovered that part number 3389946 did not have continuity. I replaced the part with part number 3977393. I connected everything, started the dryer back up and blew the thermal fuses.
I purchased kit 279816 - but am not sure whether to connect them, because I do not want to blow another fuse and don't want to waste my money. I tested for continuity in part 3387134 and did have continuity on the outside terminals but the inside terminals I did not have continuity. I took the lead wires off, turned the dryer on and made continuity using needlenose pliers and the heating element still did not shut off.
I am wondering if I should install the kit, or if I need another part...help!:confused:
That kit your got last (279816) isn't high enough it will ast a while but it isn't the correct one for your dryer. You need 279769 which has a high limit thermostat in it.
Nat
Thanks Nat. What about prt 3387134 - or is it working correctly with the inside terminals not having continuity?
Thanks - I really appreciate it
Is that an original part?
Nat
thats the one that is on there and we bought it brand new.the diagram on theback of the dryer is calling it a thermostat heater 5600-8400 ohms I believe sorry to be a pain I'm just not sure if this is my only problem or what
Those inner terminals do not have continuity until the unit is heating.
Nat
Does the element itself have continuity?
Nat
yes I have continuity on the outter stabs but nice to know that I don"t need it on the inner one. so you think by changing that thermal fuse that it will fix the problem.it all started off with a clogged pipe and 2 days later here I am still messing with it .Iwant to thank you for all your help
