2 Pages12>
greene_m
#1 Posted : Thursday, November 20, 2008 3:50:57 PM(UTC)
greene_m
Two days ago, my dryer quit heating. I took the back off and checked for continuity on the thermal fuses - I am an electrician. I discovered that part number 3389946 did not have continuity. I replaced the part with part number 3977393. I connected everything, started the dryer back up and blew the thermal fuses.
I purchased kit 279816 - but am not sure whether to connect them, because I do not want to blow another fuse and don't want to waste my money. I tested for continuity in part 3387134 and did have continuity on the outside terminals but the inside terminals I did not have continuity. I took the lead wires off, turned the dryer on and made continuity using needlenose pliers and the heating element still did not shut off.
I am wondering if I should install the kit, or if I need another part...help!:confused:
libertyappl
#2 Posted : Thursday, November 20, 2008 4:18:02 PM(UTC)
libertyappl
That kit your got last (279816) isn't high enough it will ast a while but it isn't the correct one for your dryer. You need 279769 which has a high limit thermostat in it.
Nat
greene_m
#3 Posted : Thursday, November 20, 2008 4:26:07 PM(UTC)
greene_m
Thanks Nat. What about prt 3387134 - or is it working correctly with the inside terminals not having continuity?
Thanks - I really appreciate it
libertyappl
#4 Posted : Thursday, November 20, 2008 4:28:23 PM(UTC)
libertyappl
This is what that part should look like Part Details - WHIRLPOOL Dryer cycling thermostat, L155-25, part number: 3387134 and it only has two terminals.
Nat
greene_m
#5 Posted : Thursday, November 20, 2008 4:51:03 PM(UTC)
greene_m
libertyappl
#6 Posted : Thursday, November 20, 2008 5:06:44 PM(UTC)
libertyappl
Is that an original part?
Nat
greene_m
#7 Posted : Thursday, November 20, 2008 5:18:18 PM(UTC)
greene_m
thats the one that is on there and we bought it brand new.the diagram on theback of the dryer is calling it a thermostat heater 5600-8400 ohms I believe sorry to be a pain I'm just not sure if this is my only problem or what
libertyappl
#8 Posted : Thursday, November 20, 2008 5:21:07 PM(UTC)
libertyappl
Those inner terminals do not have continuity until the unit is heating.
Nat
libertyappl
#9 Posted : Thursday, November 20, 2008 5:33:43 PM(UTC)
libertyappl
Does the element itself have continuity?
Nat
greene_m
#10 Posted : Thursday, November 20, 2008 5:42:46 PM(UTC)
greene_m
yes I have continuity on the outter stabs but nice to know that I don"t need it on the inner one. so you think by changing that thermal fuse that it will fix the problem.it all started off with a clogged pipe and 2 days later here I am still messing with it .Iwant to thank you for all your help
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
2 Pages12>
