jmj
#1 Posted : Thursday, May 26, 2011 6:17:22 AM(UTC)
jmj
Oven ignitor wont glow.Replaced with new ignitor.Have voltage at ignitor but won't glow unless I ground wire going from ignitor to oven safety valve.Gas does not turn on. Is this problems with oven safety valve or related wiring? What tests can I perform to determine problem?
#2 Posted : Thursday, May 26, 2011 3:18:14 PM(UTC)
How did you measure the voltage at the igniter?
Here are the breakdown diagrams and Replacement parts for General Electric JGBP30GEV1WH Gas range | AppliancePartsPros.com
jmj
#3 Posted : Thursday, May 26, 2011 6:29:35 PM(UTC)
jmj
With digital volt-ohmeter. If I touch the leads across the ignitor I register nothing. But touching the wire that I assume comes from the temp control up top & the other probe to any metal part of the oven I read good voltage.
#4 Posted : Monday, May 30, 2011 5:40:53 PM(UTC)
Sorry for the delay.
Sounds like the problem is a bad gas safety valve.
There are four terminals on that valve in your range. One pair is for the Bake and another pair is for the Broil. Locate the pair which is responsible for the Bake. Disconnect the wires from those terminals and check for continuity between terminals. If there is no continuity, replace the gas safety valve.
- The gas safety valve Part number: AP2022753
jmj
#5 Posted : Thursday, June 2, 2011 5:51:14 PM(UTC)
jmj
OK Gene thanks for the help. Tested terminals, no continuity. Am going to order safety valve. Will let you know how it turns out. Thanks again.
jmj
#6 Posted : Sunday, June 5, 2011 6:42:50 AM(UTC)
jmj
Thanks for the help Gene. Replaced gas safety valve.Oven works fine. Baked myself some chocolate chip cookies.:)
#7 Posted : Monday, June 6, 2011 2:27:50 PM(UTC)
You are welcome. I'm glad it's up and running.
Whirlpool WFG505MOBS0 - Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by JeffraKing 11/15/2023 9:09:08 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 6:36:01 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
Oven won't light (Oven Repair (including Ranges and Cooktops))
by davidr222 7/31/2014 7:01:18 AM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 4:55:33 PM(UTC)
Oven won't light; shuts off with F2 Error during pre heat (Oven Repair (including Ranges and Cooktops))
by MaxRock 11/21/2013 2:12:32 PM(UTC)
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 4:36:10 AM(UTC)
Frigidaire oven won't light (Oven Repair (including Ranges and Cooktops))
by baltojeff 12/7/2012 6:58:35 AM(UTC)
Roper Oven won't light (Oven Repair (including Ranges and Cooktops))
by LoneMedic 11/9/2012 10:15:54 AM(UTC)
gas broiler and oven won't light (Oven Repair (including Ranges and Cooktops))
by rickric 8/27/2012 4:16:55 PM(UTC)
GE Profile, oven won't light (Oven Repair (including Ranges and Cooktops))
by Buggus 8/1/2012 4:05:34 AM(UTC)
by gregew 7/10/2012 7:47:10 AM(UTC)
