TaniaH
#1 Posted : 14 years ago
TaniaH
Refrigerator is too cold. Originally started with just the bottom crisper bin freezing contents but after several attempted repairs, the entire fridge is 25-27 degrees. Temp is verified by a separate thermometer placed on top shelf
Settings: Freezer -6, Fridge - 47 (max settings)
Repairs: New Temp control board - no change. Swapped thermostat with one from another Frigidaire unit - no change. New damper and frig thermostat - whole fridge is now 25-27 degrees. Replaced damper with original one - no change. Replaced freezer thermostat - no change.
The doors close properly and the unit defrosts regularly.
What else could it be?
idgie57
#2 Posted : 14 years ago
idgie57
Has this been repaired yet? If so, what was the final fix? I have exactly the same problem, with even colder temps in the refr section (22 degrees) and my unit is less than 6 months old.
TaniaH
#3 Posted : 14 years ago
TaniaH
I had another repairman come look at the problem, and he says it is the main power board located underneath the freezer side. I have not yet purchased this part to try to fix it myself, so not sure if this will in fact fix the problem.
idgie57
#4 Posted : 14 years ago
idgie57
Thanks! Repair people came out yesterday, changed out something in/near the control panel (I wasn't home) and when I got home from work today, the control panel read 50 and thermometer inside read 28. Go figure. They are coming out again on Friday, we'll see what happens then... I'll suggest your diag to them and see what happens.
idgie57
#5 Posted : 14 years ago
idgie57
...And after the last repair call, guess what the problem NOW is? The motherboard under the freezer side. On order... we will see if this works.
Top freezer refrigerator too cold. (Refrigerator & Freezer Repair)
by yaworski 4 years ago
Samsung Refrigerator too cold (Refrigerator & Freezer Repair)
by jim.grove1 5 years ago
Kitchen Aid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by txh123 8 years ago
Frigidaire S x S refrigerator too cold (Refrigerator & Freezer Repair)
by APPLIANCEDUDE1972 10 years ago
GE refrigerator too cold, unstable temp cycle (Refrigerator & Freezer Repair)
by James2000 11 years ago
Kenmore side by side refrigerator too cold (Refrigerator & Freezer Repair)
by Fisheyeii 11 years ago
Refrigerator too cold, Freezer melting and refreezing (Refrigerator & Freezer Repair)
by ejnelson24 12 years ago
KitchenAid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by famcar 12 years ago
Refrigerator too cold and uncontrolable (Refrigerator & Freezer Repair)
by nailerdog 13 years ago
by Old Wino 13 years ago
Refrigerator Too Cold Vegetables Freezing (Refrigerator & Freezer Repair)
by olgapico 13 years ago
by lgray215 13 years ago
by jimmybass 14 years ago
by Paul Sobus 14 years ago
Refrigerator too cold (Dishwasher Repair)
by DEEDEEGOGO 14 years ago
