davidderrickson
#1 Posted : Tuesday, April 26, 2011 8:33:53 AM(UTC)
davidderrickson
My compressor (2006 Bryant) outside will not come when I set the thermostat lower then the room temperature.
I replace the contact switch as a guess but still doesn't work.
I can manually start the compressor (will cool the house) by pushing in the contact switch but once I let go the switch comes back out.
Question is: why is the contact switch no being tripped? Is it the capacitor or the circuit board?
icehouse
#2 Posted : Tuesday, April 26, 2011 10:18:11 AM(UTC)
icehouse
The low voltage circuit energizes(closes) the contactor.
This is done when the thermostat calls for cooling the coil of the contactor is what causes it to close.
Possibleities are bad thermostat or bad step-down transformer.(220v-24v)
gkers2006
#3 Posted : Sunday, May 15, 2011 5:31:23 AM(UTC)
gkers2006
you must not be getting 24 volts from your thermostat to contactor
wrightimc
#4 Posted : Tuesday, May 17, 2011 1:34:18 PM(UTC)
wrightimc
I think it's better to get a professional opinion.. most of the AC companies have free consultation... just call them and ask for a free quote or something... I usually call Reliant Air Conditioning... they're pretty good..
gkers2006
#5 Posted : Tuesday, May 17, 2011 1:46:29 PM(UTC)
gkers2006
i am a pro write, been doing service for 34 yrs.
icehouse
#6 Posted : Tuesday, May 17, 2011 2:47:00 PM(UTC)
icehouse
A short timer myself 44years, Also father before me, grandfather started company 1899 :eek:
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
Kitchenaid KSRG25FKSS15 Refridg buzz/rattle on compressor start (Refrigerator & Freezer Repair)
by Guest 6/23/2024 8:35:15 AM(UTC)
True GDM-26-LD Display Fridge compressor issues (Refrigerator & Freezer Repair)
by KSlank76 6/22/2024 10:24:23 PM(UTC)
Frigidaire PLHS238ZCB1 Refigerator compressor issues. (Refrigerator & Freezer Repair)
by TonyMertz 5/18/2024 9:32:13 PM(UTC)
Compressor Start Device constantly needs replacing (Refrigerator & Freezer Repair)
by norsemen 3/11/2024 2:17:34 PM(UTC)
Compressor & condenser fan not running - low voltage, start relay ok (Refrigerator & Freezer Repair)
by Guest 1/17/2024 11:51:38 AM(UTC)
Amana compressor issues (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:42:43 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Refrigerator inverter compressor not starting (Refrigerator & Freezer Repair)
by Guest 11/1/2023 4:24:39 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Not defrosting and motor/compressor running constantly (Refrigerator & Freezer Repair)
by egizzi 3/23/2023 7:05:21 PM(UTC)
compressor start relay question (Refrigerator & Freezer Repair)
by Guest 10/16/2022 2:45:39 AM(UTC)
Noisy Commercial Refigerator Compressor (Refrigerator & Freezer Repair)
by djsource 9/18/2022 12:24:54 PM(UTC)
Embraco EMI30HER Compressor - is it toast? (Refrigerator & Freezer Repair)
by Guest 5/10/2022 4:59:08 AM(UTC)
