candace
#1 Posted : Thursday, October 30, 2008 4:13:19 PM(UTC)
candace
My dryer won't shut off at end of cycle like it used too.
v2k04
#2 Posted : Thursday, October 30, 2008 4:24:15 PM(UTC)
v2k04
Continue using it untill it totally quits working and at that point go find yourself another one, by now the plastic bearing in front is starting to crumble to pieces the slides are shot the heat element is sagging and about ready to short together and if they used a white plastic rear bearing it's about shot as well. Not to mention the blower assy is packed full of lint and making the motor run hot. When GE made those machines they didn't want you repairing them. But would rather see it crushed and recycled into something else
kayakcrzy
#3 Posted : Friday, October 31, 2008 4:38:02 AM(UTC)
kayakcrzy
Are we a little cynical this morning. Tom ApplianceEducator.com
magician59
#4 Posted : Friday, October 31, 2008 8:38:40 AM(UTC)
magician59
So, did I waste my friend's money by replacing his thermostats? His dryer was overheating. I also recommended a chimney sweep (the home builders in my area vent dryers through the roofs here). I don't remember his mod. #, but it is a late model GE.
kayakcrzy
#5 Posted : Friday, October 31, 2008 2:00:49 PM(UTC)
kayakcrzy
No you did not waste your friends money. Tom ApplianceEducator.com
v2k04
#6 Posted : Friday, October 31, 2008 7:28:44 PM(UTC)
v2k04
Does it show?
Amana dryer will not shut off on automatic cycles (Dryer Repair)
by Nutforbriggs 4/21/2016 11:42:33 AM(UTC)
Maytag MDE7658BYW Timer not advancing/dryer will not shut off (Dryer Repair)
by countrybois 6/13/2014 10:47:30 AM(UTC)
Dryer will not shut off (Dryer Repair)
by patpeery@aol.com 11/22/2012 10:01:07 AM(UTC)
Whirlpool dryer will not shut off after new timer replacement (Dryer Repair)
by grayfeathers 10/23/2012 4:23:08 PM(UTC)
Dryer will not shut off in automatic cycle (Dryer Repair)
by jennarnott 6/21/2012 12:02:09 PM(UTC)
Dryer will not Shut off (Dryer Repair)
by Jeremybrutonsupply 5/25/2012 6:00:53 AM(UTC)
HELP! Dryer will not shut off & timer won't advance (Dryer Repair)
by csutliff 4/11/2012 10:17:10 AM(UTC)
Maytag Dryer Will Not Shut Off (Dryer Repair)
by MJScott 3/20/2012 11:35:17 AM(UTC)
Maytag Dryer Will Not Shut Off (Refrigerator & Freezer Repair)
by MJScott 3/20/2012 11:27:36 AM(UTC)
kenmore dryer will not shut off and will start when the timer is on zero (Dryer Repair)
by brettb 12/13/2011 4:05:19 PM(UTC)
LDG8414AAE Maytag Dryer will not shut off (Dryer Repair)
by skora 11/3/2011 11:42:33 AM(UTC)
by GWG 12/30/2010 7:53:55 AM(UTC)
Dryer will not shut off but heats ok (Dryer Repair)
by twilliams0204 12/16/2010 6:26:06 PM(UTC)
by fixit33 10/4/2010 4:08:20 AM(UTC)
Dryer will not shut off. (Dryer Repair)
by jmkitson 8/5/2010 11:23:31 AM(UTC)
