brettb
#1 Posted : Tuesday, December 13, 2011 4:05:19 PM(UTC)
brettb
my dryer will not shut off when the timer goes to zero. i have to open the door to get it to shut off. also, it will start when the timer is on zero when you push the start button. the dryer heats well
#2 Posted : Wednesday, December 14, 2011 2:13:22 AM(UTC)
Replacement parts for KENMORE 11062802100 | AppliancePartsPros.com
Sounds like the timer is shot re: the BK/BU contacts are welded together.
I could not find a wiring diagram for this unit so I looked up another unit that uses the same timer. Yours should be close. See the attachment.
Check in your control console, they like to store diagrams in there.
Part number: AP3100522
You can confirm that the contacts are shot by:
Unplug the unit.
Unplug the wires going either to the BK or BU connection.
This prevents you from reading an alternate/parallel circuit path.
Set the timer to off.
Measure across the contacts.
Should be infinite ohms (open).
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
Example Wiring.pdf (269kb) downloaded 5 time(s).
im8123397
#3 Posted : Monday, November 2, 2015 1:39:14 PM(UTC)
im8123397
Apologies on resurrecting this thread 4 years later but I am experiencing a similar problem and need some assistance. I have a Kenmore 300 dryer (model # 110.68322700) that will not shut off when the timer gets to the off position. It shuts off fine when the door is opened but if I close the door, leave it in the off position, and push the start button, it starts right up.
All of the continuity checks for the timer are where they should be based on the wiring diagram. The timer motor still moves correctly and when I check the continuity in the off position, there is no continuity from the BK (power in) side of the timer switch to the BU (power to the motor) side of the timer. Additionally, I have checked that the heating element is not grounded and the thermostats are all good. The only slightly abnormal thing I could find is that the resistance across the heating element is 0 ohms where the wiring diagram shows that it should be 7.8-11.8 ohms. The element itself looks fine and is not shorting anywhere that I can see. The dryer is providing hot air and dries clothes fine, it just won't stop running until I open the door when it's in the off position.
I would appreciate any help anyone could offer. Let me know if you need any amplifying information.
