mdssales
#1 Posted : Thursday, September 18, 2008 6:55:35 AM(UTC)
mdssales
Washer is leaking from under the tub afterit starts its wash cycle, not leaking while tub is filling with water only after wash or rinse cycle begins
libertyappl
#2 Posted : Thursday, September 18, 2008 8:02:17 AM(UTC)
libertyappl
That sounds like the tub seals, you can see the breakdown on the machine here Model MAV7600AWW. Go to page 7 (tub). Raise the top panel & remove the front panel and run a wash cycle to see where iexactly it is leaking from.
Nat
mdssales
#3 Posted : Friday, September 19, 2008 3:20:26 AM(UTC)
mdssales
It seems to be leaking from just under the tub where the transmission connects to the aggitator. What would need to be replaced? Are there and instruction manuels to explain how to make the repairs? are there any special tools required for these repairs? Is it in your opinion worth repairing or should I look at replacing the washer?
libertyappl
#4 Posted : Friday, September 19, 2008 7:14:16 AM(UTC)
libertyappl
A lot of parts come with the instructions, don't remember if the seals do or not. It is repairable just time consuming and can be a pain in the ***.
It's worth repairing and it doesn't require any special tools, sometimes a extra set of hands are nice! Look at the breakdown and get all the seals inthe area.
Nat
Leaking Washer (Washer Repair)
by midget73 7/27/2014 3:27:00 PM(UTC)
by broonsparrow 11/30/2013 10:15:30 AM(UTC)
Leaking washer need advice (Washer Repair)
by GE Nightmare 10/5/2013 1:54:30 PM(UTC)
leaking washer (Washer Repair)
by ashkdaot 6/25/2013 6:23:18 PM(UTC)
by Jags 12/22/2012 8:37:52 AM(UTC)
by martha725 8/3/2012 2:11:37 PM(UTC)
leaking washer and won't drain (Dishwasher Repair)
by colt 11/6/2011 2:15:14 PM(UTC)
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 11/5/2011 6:14:56 PM(UTC)
Leaking washer (Washer Repair)
by Crowell 9/6/2011 9:11:30 AM(UTC)
leaking washer during filling (Washer Repair)
by bonnetinsurance 8/10/2011 7:44:44 AM(UTC)
by 03svrider 6/9/2011 10:48:37 AM(UTC)
by rcarroll7703 6/1/2011 7:50:27 AM(UTC)
by donandlynn 5/7/2011 7:32:41 AM(UTC)
by Mrkis 1/30/2011 9:09:01 AM(UTC)
by Clueless101 12/27/2010 12:33:13 PM(UTC)
