bigdanallan
#1 Posted : Thursday, January 20, 2011 7:42:20 PM(UTC)
bigdanallan
re: GE part water level switch; #AP2045895, is it adjustable and what is the procedure, to raise or lower the water level? thanks dan
sidfink43
#2 Posted : Sunday, January 23, 2011 4:59:17 PM(UTC)
sidfink43
The water level switch is not adjustable. Replace it if necessary but first clean out the tube that runs from it to the tub. That may be your problem.
Water level switch and something else maybe? (Washer Repair)
by tomsteve 2/19/2015 1:11:10 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
Water still not stopping after water level switch replaced (Washer Repair)
by LIsa60 5/19/2014 5:33:24 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
Rinse - low water level - 2 Water Level Switches... (Washer Repair)
by Aleste 1/25/2013 4:20:37 AM(UTC)
Replacing water level switch (Washer Repair)
by Socalguy84 11/21/2012 8:07:56 AM(UTC)
by dellmack 8/28/2012 7:19:10 PM(UTC)
Two water level switches bad in 12 months? (Washer Repair)
by jfwilliams3 7/26/2011 8:35:32 PM(UTC)
installing water level switch (Washer Repair)
by chrisjay 3/4/2011 5:55:11 AM(UTC)
Whirlpool Calypso Water Level Switch (Washer Repair)
by diyhelp 12/20/2010 6:14:21 AM(UTC)
by bowerman 11/2/2010 6:19:03 PM(UTC)
washer---water level switch (Washer Repair)
by brian_b@mail.com 10/26/2010 12:22:27 PM(UTC)
repairing a water level switch (Washer Repair)
by repairman756 1/10/2010 11:53:05 AM(UTC)
how do you test water level switch (Washer Repair)
by ldutton 10/11/2009 7:04:15 PM(UTC)
Washer Water Level Switch Continuity Test (Washer Repair)
by td940 9/22/2009 10:29:57 AM(UTC)
