2 Pages12>
Madmaxx383
#1 Posted : Wednesday, August 27, 2008 10:19:50 AM(UTC)
Madmaxx383
My daughter thought she was setting the timer but set the microwave to run for 1 hour. Now microwave is dead no lights no display no power. Is there a reset, or a thermal fuse I can replace? And how would I go about doing this?
libertyappl
#2 Posted : Wednesday, August 27, 2008 10:21:43 AM(UTC)
libertyappl
Can you post the model number from the tag insdie the microwave.
Madmaxx383
#3 Posted : Wednesday, August 27, 2008 10:23:41 AM(UTC)
Madmaxx383
GE Spacemaker Model # JVM1870SF001
libertyappl
#4 Posted : Wednesday, August 27, 2008 10:33:51 AM(UTC)
libertyappl
Ok you do have a fuse behind the control panel, which may or may not be your problem. I'm assuming the MW was empty? If you go to searspartsdirect website you can look at the breadown of your MW and see where the fuse is, you will want to check the fuse for continuity if none then replace with AP2631556 from this site(cheapest place to get parts most of the time).
Let us know whatelse we can do to help. If it looks like something you aren't comfortable with call a tech!!! there are some parts in there that can really "bite" you badly.
abadfish66
#5 Posted : Wednesday, August 27, 2008 10:36:33 AM(UTC)
abadfish66
The cavity tco needs to be replaced or fixed. it is located behind the exhast grill. Take off the grill by removing the top 2 screws and sliding it to the left and then it will pull off. Then in the middle area, there is a metal plate held on by 1 screw. Remove the screw and the plate. Now over to the left, you can follow the 2 black wires, there is a small round device. Remove that. That is your cavity tco. You can try to freeze it to reset it, or order a new one.
abadfish66
#6 Posted : Wednesday, August 27, 2008 10:44:08 AM(UTC)
abadfish66
Madmaxx383
#7 Posted : Wednesday, August 27, 2008 11:12:39 AM(UTC)
Madmaxx383
Just tested fuse continuity on the main and hv fuses. Both are good-Can you be more specific on how to get to and remove tco-- allready removed cover the black wires run underneath something and come out in the back left side
abadfish66
#8 Posted : Wednesday, August 27, 2008 11:16:21 AM(UTC)
abadfish66
When you took off the vent cover, and the metal cover behind that, do you see a small round motor right in front of you? It will be to the left and that, get a flashlight and shine in there, you should see it.
Madmaxx383
#9 Posted : Wednesday, August 27, 2008 11:24:12 AM(UTC)
Madmaxx383
Is there a way to test resistance on the tco to determine if the sensor has failed-I have it in the freezer right now, but I would like to know if there is a way to know for sure which piece has truly failed
abadfish66
#10 Posted : Wednesday, August 27, 2008 11:26:03 AM(UTC)
abadfish66
Basically it is open or it is closed. Doing a continuity check on the 2 leads will tell you if it is open or closed.
Guest (11)
Microwave has no power (Microwave Repair)
by Frank10 2/9/2018 2:22:28 PM(UTC)
Kitchenaid built in oven - microwave has no power (Oven Repair (including Ranges and Cooktops))
by wilsjay 1/19/2016 10:40:25 AM(UTC)
microwave has no power (Microwave Repair)
by justhelpme 10/6/2013 6:33:55 AM(UTC)
by mileyack 1/13/2012 9:01:06 AM(UTC)
Microwave has no power. (Microwave Repair)
by garystarh 12/6/2011 8:30:07 AM(UTC)
Whirlpool Microwave has no power (Microwave Repair)
by 87kustom 11/22/2011 4:21:14 PM(UTC)
Microwave has no power, replaced fuse 1.5yro (Microwave Repair)
by scress 8/22/2007 11:11:21 AM(UTC)
2 Pages12>
