garystarh
#1 Posted : 13 years ago
garystarh
Customer opened door and light came on. But, she cannot set the functions to make the microwave work. Door closes fine.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
If when she tries to set the functions it's like the buttons don't work then I would check the membrane switch ribbon cable for a bad connection. The ribbon cable end may need to be cleaned with a pencil eraser. I would also check the control board were the ribbon cable plugs into for bad solder connections.
