Dryer will not start. Do not have ohm meter. Would likely cause be the thermal fuse or the timer /push button itself ?
Most likely the thermal fuse, Nat
Do you know the part number for the thermal fuse ?
part number is AP415996 ( thermal kit) I suggest replacing them all but you can just replace the bad one and use the others later if needed. Nat
