gcw
#1 Posted : Friday, August 15, 2008 8:13:01 AM(UTC)
gcw
My three-year-old Kenmore refrigerator is freezing food in the fresh food section. What is causing this problem?
libertyappl
#2 Posted : Friday, August 15, 2008 10:17:14 AM(UTC)
libertyappl
Check your settings for the refrigerator section to make sure they aren't turned up to high. If they aren't your cold control may be bad.
Nat
gcw
#3 Posted : Saturday, August 16, 2008 6:06:00 PM(UTC)
gcw
Is the cold control the same as the thermostat? How do I check if it is bad?
#4 Posted : Saturday, August 16, 2008 7:28:09 PM(UTC)
In order to provide most accurate advise we need the complete model number of the refrigerator.
VinceYue
#5 Posted : Monday, August 18, 2008 7:40:46 AM(UTC)
VinceYue
Hi Gene,
I am having the same problem with my whirlpool refrigerator. Does not matter how I adjust the control knobs, the freezer and fresh food compartment are too cold. I had to throw some food away because they were frozen and became bad.
I checked the part number for my frig is : 2198202 from whirlpool.
How do I check if it is the cold control problem and how do I replace it if it is bad?
I will order the part from your website if I know for sure it is the problem and how to fix it.
#6 Posted : Monday, August 18, 2008 11:52:03 AM(UTC)
Hi Vince,
What is the complete model number of the refrigerator? What is the temperature in both compartments?
vito675
#7 Posted : Monday, August 18, 2008 12:27:52 PM(UTC)
vito675
check your damper
VinceYue
#8 Posted : Wednesday, August 20, 2008 3:38:30 AM(UTC)
VinceYue
Hi Gene,
The model is: GD2LHGXKQ00, made by whirlpool.
Yesterday, I bought a thermometer, and measured the temps in both freezer and fresh food section, they are -15.5 F and 28 F. I tried different settings, but did not work. The compressor seems working all the time, except when it goes to defrost cycle for about 25 minutes.
I tried to turn it off, when turn the knob to zero, it does not shut off the compressor, I have to tab the box or turn the know or take the knob out to make it stop. Once stopped, and if I turn it on, I have to tab on the box few time and it will start.
This is to answer suggestion from Vito, when I turned the knobs to different settings, I can notice the difference of cold air blown out from the freezer to the fresh food section (top left ).
#9 Posted : Wednesday, August 20, 2008 11:53:20 AM(UTC)
Hi Vince,
The problem is a bad thermostat (aka cold control), no doubt about it.
- The part number for the thermostat is AP3037004
You can find the complete instructions with a pictures in one of our previous posts: http://forum.appliancepartspros...control-box-removal.html
Here are the break down diagrams for the Whirlpool refrigerator Model GD2LHGXKQ00
Frigidaire 'Tall Twin' Refrigerator is freezing food. (Refrigerator & Freezer Repair)
by jbeal9 6/24/2020 12:23:53 PM(UTC)
Refrigerator is freezing food (Refrigerator & Freezer Repair)
by weldmeister 4/14/2014 10:14:26 AM(UTC)
by blarge 10/15/2012 9:20:28 AM(UTC)
Refrigerator is freezing foods - temp controlls have not been touched in years (Refrigerator & Freezer Repair)
by wmundy 9/14/2012 8:49:20 AM(UTC)
Refrigerator is freezing food in the fresh food compartment (Refrigerator & Freezer Repair)
by KodiakJim37762 5/24/2012 8:29:24 AM(UTC)
refrigerator is freezing food (Refrigerator & Freezer Repair)
by uptomealso 10/2/2011 7:59:37 AM(UTC)
Refrigerator is freezing foods (Refrigerator & Freezer Repair)
by lrobb 7/27/2011 6:41:24 PM(UTC)
by tomskitten 5/22/2011 11:13:30 AM(UTC)
by jessv9 2/1/2011 4:30:11 PM(UTC)
Freezer is fine but Refrigerator is freezing food (Refrigerator & Freezer Repair)
by critter 5/5/2009 9:28:23 AM(UTC)
