| » Control Box Removal |
Model Number: ED25TQXGW00 Brand: Whirlpool Age: 5 - 10 years
How do I remove the control box and escutcheon plate so I can replace the thermostat?
Thermostat only works if you set it max or thump on it at lower settings. Whirlpool Refrigerator ED25TQXGW00. Last edited by EDB : 01-22-2008 at 05:31 PM. |
I was looking for the same answers last night and today discovered the answer. Provided your control box is the same as mine, there are four screw that have to be removed. The two hex screws on the inside of the fridge which you can see are obvious. The not so obvious are two screws behind the faceplate of the control box. See the following diagram.Model ED25LFXGN00 Part number #3 is the screw on the left. There is another on the right hand side. In order to remove the face plate you have to pry it off from the top and work your way across the top edge. Then it will lift off. I have attached a couple of photos so you can see the back of the faceplate and the control box with the faceplate removed. Hope this helps. |
| Display Modes | |
| Baffle removal | a.faden@worldnet.att.net | Dryer Repair | 1 | 01-17-2008 09:54 AM |
| oven control removal | ericnor | Oven Repair (including Ranges and Cooktops) | 1 | 11-10-2007 09:06 PM |
| Front Control Panel Removal | dwfunk32 | Oven Repair (including Ranges and Cooktops) | 0 | 10-05-2007 10:13 AM |
| Control Panel Removal | PeteME | Dishwasher Repair | 1 | 10-03-2007 08:55 PM |
| Transmission Removal | Street777 | Washer Repair | 0 | 08-01-2007 05:57 PM |
